Author Topic: LISP FOR CHANGING EVERY POLYLINE WITH WIDHT, COLOUR TO 252.(INCLUDING BLOCKS)  (Read 4611 times)
PPETROS
Dear all,
I am struggling to write a lisp routine which does the followings:
    • Select *Every polyline with a width larger than 0 (zero)
    • Change their color to a specific one, predefined (i.e. 252)
*Every polyline including blocks.(And nested)
The attached routine “Code 1” changes the color of all polyline with width larger that 0 (zero), but not that inside blocks
(DEFUN C:P252 ()
(setq S2 (ssget "_X" (list (cons 0 "*POLYLINE")
 (cons -4 ">")
 (cons 40 0.0))) )
(command "Change" S2 "" "p" "c" 252 "")
Furthermore, the attached routine “Code 2” changes the color (globally) of every polyline, no matter the width. (polyline with width 0)
(defun c:PL-ALL-252 ( / doc )
    (vlax-for block (vla-get-blocks (setq doc (vla-get-activedocument (vlax-get-acad-object))))
        (if (eq :vlax-false (vla-get-isxref block))
            (vlax-for obj block
                (if (eq "AcDbPolyline" (vla-get-objectname obj))
                    (vl-catch-all-apply 'vla-put-color (list obj 252))
    (vla-regen doc acallviewports)
(vl-load-com) (princ)
I would be grateful if someone can fix my code, or suggest a new one.
Thank you in advance.
Attaching example drawing:
kpblc
I didn't check code:
  1. (defun c:pl-all-252 (/ doc)
  2.     (if (eq :vlax-false (vla-get-isxref block))
  3.       (vlax-for obj block
  4.         (if (and (eq "AcDbPolyline" (vla-get-objectname obj))
  5.                  (vlax-property-available-p obj "ConstantWidth")
  6.                  (> (vla-get-constantwidth obj 0.0))
  7.                  ) ;_ end of and
  8.           (vl-catch-all-apply 'vla-put-color (list obj 252))
  9.           ) ;_ end of if
  10.         ) ;_ end of vlax-for
  11.       ) ;_ end of if
  12.     ) ;_ end of vlax-for
  13.   (vla-regen doc acallviewports)
  14.   (princ)
  15.   ) ;_ end of defun
Sorry for my English.
PPETROS
thanks for your effort
but something goes wrong
Autocad report the message  “; error: Too many actual parameters”
roy_043
  • BricsCAD 18
This:
(> (vla-get-constantwidth obj 0.0))Should be:
(> (vla-get-constantwidth obj) 0.0)
PPETROS
thanks
but something goes wrong again
Autocad report the message  “; error: Automation Error. Invalid input”
kpblc
I tried to start this code, it worked correctly:
  2.     (if (equal (vla-get-isxref block) :vlax-false)
  6.                  (> (vla-get-constantwidth obj) 0.0)
  7.                  ) ;_ end of and
  9.           ) ;_ end of if
  11.       ) ;_ end of if
  14.   (princ)
PPETROS
Run your code in my attach dwg file
it does not work there
Autocad report again the message  “; error: Automation Error. Invalid input”
thanks again for your time
kpblc
Ah, sorry
  1. (defun c:pl-all-252 (/ doc width)
  2.   (vlax-for block (vla-get-blocks doc)
  3.     (if (equal (vla-get-isxref block) :vlax-false)
  4.       (vlax-for obj block
  5.         (if (and (eq "AcDbPolyline" (vla-get-objectname obj))
  6.                  (not (vl-catch-all-error-p
  7.                         (setq width (vl-catch-all-apply (function (lambda () (vla-get-constantwidth obj)))))
  8.                         ) ;_ end of vl-catch-all-error-p
  9.                       ) ;_ end of not
  10.                  (> width 0.0)
  11.                  ) ;_ end of and
  12.           (vl-catch-all-apply 'vla-put-color (list obj 252))
  13.           ) ;_ end of if
  14.         ) ;_ end of vlax-for
  15.       ) ;_ end of if
  16.     ) ;_ end of vlax-for
  17.   (vla-regen doc acallviewports)
  18.   (princ)
  19.   ) ;_ end of defun
PPETROS
Very good job my friend.
I would like to ask something more of you.
It is easy to fix your code so that it can also change the polylines with variable width.
Check out my new attach file for more (red text).
Thanks again for your time
Try this quick mod:
  6.                  (or (vl-catch-all-error-p
  7.                        (setq width (vl-catch-all-apply 'vla-get-constantwidth (list obj)))
  9.                      (> width 0.0)
  10.                  ) ;_ end of not
  11.             ) ;_ end of and
  13.         ) ;_ end of if
  15.     ) ;_ end of if
  18.   (princ)
PPETROS
Re: LISP FOR CHANGING EVERY POLYLINE WITH WIDHT, COLOUR TO 252.(INCLUDING BLOCKS)
« Reply #10 on: September 19, 2019, 03:02:26 AM »
Excellent, that is what i wanted.
Thank you very mach
roy_043
  • BricsCAD 18
« Reply #11 on: September 19, 2019, 03:03:07 AM »
It is surprising that using vla-get-constantwidth on an "AcDbPolyline" can cause an error (BricsCAD shows the same behavior).
kpblc
« Reply #12 on: September 19, 2019, 05:33:35 AM »
That polyline has a different widths at start and at end of some segments.
David Bethel
« Reply #13 on: September 19, 2019, 08:34:07 AM »
Because you are using both light and heavy POLYLINEs, you will need to deal with them differently ( no BLOCKS Included )
  1.
  2.
  3. (defun c:pl-wide (/ ws ss en ed et i vn vd ws)
  4.
  5.   (setq ws (ssadd))
  6.
  7.   (and (setq ss (ssget "X" (list (cons -4 "<OR")
  8.                                    (cons 0 "LWPOLYLINE")
  9.                                    (cons -4 "<AND")
  10.                                      (cons 0 "POLYLINE")
  11.                                      (cons -4 "<")
  12.                                        (cons 70 8)
  13.                                    (cons -4 "AND>")
  14.                                  (cons -4 "OR>"))))
  15.         (setq i 0)
  16.         (while (setq en (ssname ss i))
  17.                (setq ed (entget en)
  18.                      et (cdr (assoc 0 ed)))
  19.                (cond ((= et "LWPOLYLINE")
  20.                       (foreach g ed
  21.                         (and (member (car g)'(40 41))
  22.                              (not (zerop (cdr g)))
  23.                              (not (ssmemb en ws))
  24.                              (ssadd en ws))))
  25.                      ((= et "POLYLINE")
  26.                       (setq vn (entnext en)
  27.                             vd (entget vn))
  28.                       (while (= "VERTEX" (cdr (assoc 0 vd)))
  29.                              (and (= 0 (cdr (assoc 70 vd)))
  30.                                   (or (/= 0 (cdr (assoc 40 vd)))
  31.                                       (/= 0 (cdr (assoc 41 vd))))
  32.                                   (not (ssmemb en ws))
  33.                                   (ssadd en ws))
  34.                              (setq vn (entnext vn)
  35.                                    vd (entget vn)))))
  36.                (setq i (1+ i))))
  37.
  38.   (if (> (sslength ws) 0)
  39.       (command "_.CHPROP" ws "" "_Color" 252 ""))
  40.
  41.   (prin1))
  42.
Not tested very thoroughly.  -David
R12 Dos - A2K
roy_043
  • BricsCAD 18
« Reply #14 on: September 19, 2019, 03:25:00 PM »
Yes, I do understand that. I meant that it is strange on a fundamental level: An object has a property, but requesting the value of that property results in an error.
« Last Edit: September 20, 2019, 05:06:56 AM by roy_043 »
