I wanted to get your feedback on "Xref'ing" dwgs that contain civil3d objects like a surface or pipe network.
I have had this issue before, where I would xref a civil3d surface into a sheet file and then the same surface would also be data referenced in the same drawing. About half the time, the surface labels would be incorrect or not matching the source dwg.
any once experience this type of behaviors?
thanks
