Author Topic: Help to add multiple selection  (Read 1737 times)
Aldo
« on: September 02, 2019, 01:37:56 PM »
Greetings dear friends
I have a routine that eliminates the overlapping vertices of a polyline, I would like you to help me modify it, what I would like is to allow me to make a multiple selection of polyline, I am very grateful for the support provided.
regards
;;; Clean_poly (gile)
;;; Elimina todos los vértices superpuestos de las polilíneas, optimizados, 2D y 3D
;;; TRUNC (gile)
;;; Devuelve la lista truncada de la primera aparición
;;; de la expresión (lista complementaria de la devuelta por el MIEMBRO)
(defun trunc (expr lst)
  (if (and lst
      (not (equal (car lst) expr))
    (cons (car lst) (trunc expr (cdr lst)))
;;; Fonction principale
(defun c:clean_poly (/ ent e_lst p_lst vtx1 vtx2)
  (while (not
      (setq ent (car (entsel "\nSeleccione una polilínea: ")))
  (setq e_lst (entget ent))
    ((= "LWPOLYLINE" (cdr (assoc 0 e_lst)))
     (setq p_lst (vl-remove-if-not
         '(lambda (x)
            (or (= (car x) 10)
           (= (car x) 40)
           (= (car x) 41)
           (= (car x) 42)
         e_lst
      e_lst (vl-remove-if
         '(lambda (x)
            (member x p_lst)
         e_lst
     (if (= 1 (cdr (assoc 70 e_lst)))
       (while (equal (car p_lst) (assoc 10 (reverse p_lst)))
    (setq p_lst (reverse (cdr (member (assoc 10 (reverse p_lst))
                  (reverse p_lst)
     (while p_lst
       (setq e_lst (append e_lst (trunc (assoc 10 (cdr p_lst)) p_lst))
        p_lst (member (assoc 10 (cdr p_lst)) (cdr p_lst))
     (entmod e_lst)
    ((and (= "POLYLINE" (cdr (assoc 0 e_lst)))
     (zerop (logand 240 (cdr (assoc 70 e_lst))))
     (setq e_lst (cons e_lst nil)
      vtx1    (entnext ent)
      vtx2    (entnext vtx1)
     (while (= (cdr (assoc 0 (entget vtx1))) "VERTEX")
       (if (= (cdr (assoc 0 (entget vtx2))) "SEQEND")
      (or (not
       (equal   (assoc 10 (entget vtx1))
         (assoc 10 (last (reverse (cdr (reverse e_lst)))))
          (zerop (logand 1 (cdr (assoc 70 (last e_lst)))))
       (setq e_lst (cons (entget vtx1) e_lst))
      (not
        (equal (assoc 10 (entget vtx1)) (assoc 10 (entget vtx2)) 1e-9)
       (setq vtx1 vtx2
        vtx2 (entnext vtx1)
     (setq e_lst (reverse (cons (entget vtx1) e_lst)))
     (entdel ent)
     (mapcar 'entmake e_lst)
    (T (princ "\nEntidad inválida."))
