Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
If possible help with the conversion "13204.74087\\P16224.7943\\P2.56"
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: If possible help with the conversion "13204.74087\\P16224.7943\\P2.56" (Read 1814 times)
HOSNEYALAA
Newt
on:
August 27, 2019, 10:32:51 AM »
Hello all
If I have this sentence
How can i turn it into
(13204.74087 16224.7943 2.56)
Thanks in advance
Logged
Needs a day job
Re: If possible help with the conversion "13204.74087\\P16224.7943\\P2.56"
Reply #1 on:
August 27, 2019, 11:18:43 AM »
Something like this:
Code - Auto/Visual Lisp:
[Select]
read
strcat
vl-string-translate
P"
"13204.74087
P16224.7943
P2.56"
Or do a search for 'parse string' .. there are numerous examples.
Probably most used:
http://www.lee-mac.com/stringtolist.html
Last Edit: August 27, 2019, 11:51:56 AM by ronjonp
Logged
Tharwat
Swamp Rat
Hypersensitive
WWW
Reply #2 on:
August 27, 2019, 11:25:34 AM »
Your string must have been retrieved from Mtext object.
so you can use the following function:
[Select]
defun
_peelstring
string del
str pos lst
;; Tharwat - date: 07.Nov.2015 ;;
while
setq
pos
vl-string-search
del string
0
setq
str
substr
string
1
pos
string
substr
string
pos
1+
strlen
del
and
str
str
setq
lst
cons
str lst
and
string
string
setq
lst
cons
string lst
reverse
lst
The return would be in a string format:
[Select]
_peelstring
"13204.74087
P16224.7943
P2.56"
P"
Logged
HVAC, Plumbing, Drainage, Electricity , Fire Fighting Programs and many more .....
HOSNEYALAA
Newt
Reply #3 on:
August 28, 2019, 01:57:23 AM »
Thank you so much
Tharwat
The solution is good
And it works great
Thank you
Logged
Tharwat
Swamp Rat
Hypersensitive
WWW
Reply #4 on:
August 28, 2019, 04:58:28 AM »
You're welcome anytime.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
