Author Topic: Searching for a length lisp  (Read 3334 times)
HasanCAD
« on: August 26, 2019, 03:43:43 AM »
I am wondering if there a lisp to do this task
I have a poyline and want to add length for each segment as attached image 1
and the length as image 2
Thanks in advance
Re: Searching for a length lisp
« Reply #1 on: August 26, 2019, 08:15:18 AM »
« Reply #2 on: August 26, 2019, 08:17:05 AM »
More routines-----------   Length and Area   ------------------
Length of Objects by CAB - pick each object & displays
the object type, length & a running total on the command line.
http://www.theswamp.org/index.php?topic=5891.0
http://www.theswamp.org/index.php?topic=5891.msg268984#msg268984
Lengthen Command with Options by CAB - lengthen command
with key press switch  from Lengthen to Shorten
http://www.theswamp.org/index.php?topic=23871.0
http://www.theswamp.org/index.php?topic=29270.0 Line Length Calculator by Lee Mac
http://www.lee-mac.com/intersectionslength.html  Line Length Calculator by Lee Mac
http://www.theswamp.org/index.php?topic=20345.0 Areas of objects by Mark Thomas
http://www.theswamp.org/index.php?topic=33671.0  Show Total by Andrea
BIGAL
  • 40 + years of using Autocad
« Reply #3 on: August 27, 2019, 06:34:17 AM »
CAB may have missed this one also http://www.lee-mac.com/polyinfo.html
Hansancad need the length of the curves also should be dimmed maybe with radial dim.
HasanCAD
« Reply #4 on: August 28, 2019, 11:42:53 AM »
How to avoid if there is a curved part and measure one side of polyine not 2 sides as attached image 2
Thanks in advance
« Reply #5 on: August 28, 2019, 05:10:32 PM »
You could use inters on the straight segments and remove the segments with bulges > 0. Here is some code to get the apparent intersection of 2 picked segments.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/need-lisp-please/m-p/8979192#M388932
BIGAL
« Reply #6 on: August 29, 2019, 02:34:37 AM »
Like Ronjonp copy existing pline, remove bulges, dim this pline then erase new pline, so dims should be in correct places.
Bulge remove fillet r 0 Last Polyline
Now where is that auto dim pline.
HasanCAD
« Reply #7 on: August 31, 2019, 10:23:47 AM »
Up to here is OK and can do that
But dim shall measure both sites of Pline
how to delete duplicate dim  ?
BIGAL
« Reply #8 on: September 03, 2019, 01:15:11 AM »
Trying to find some time as the dims are created using the vertices points it will only ever dim once. Need a autodim pline.
Need some more time I need to redo a couple of routines that check a few things like pline direction. So left right are correct.
; dimension a pline from vertices
; does not support bulges
; By AlanH Consulting info@alanh.com.au
; SEP 2019
(defun c:AHpldim ( / lst x y lst2 pt3 pt)
(setq plent (entsel "Pick pline near start end"))
(setq pt  (cadr plent) )
(setq obj (vlax-ename->vla-object (car plent)))
(setq pt1 (vlax-curve-getstartpoint obj))
(setq pt2 (vlax-curve-getendpoint obj))
(setq offd (getdist "Enter offset distance  "))
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(setq dir (ah:butts 1 "h"  '("Left or right" "Right" "Left")))
(if plent (setq lst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent))))))
(if (< (distance pt pt1)(distance pt pt2))
(setq lst (reverse lst))
(setq x 0)
(repeat (- (length lst) 1)
(setq pt1  (nth x lst))
(setq pt2 (nth  (+ x 1) lst))
(if (= dir "Right")
(setq pt3 (polar pt1 (+ (/ pi 2.0)(angle pt1 pt2)) offd))
(setq pt3 (polar pt1 (- (angle pt1 pt2)(/ pi 2.0)) offd))
(command "Dim" "aligned" pt1 pt2  pt3 "" "exit" )
(setq x (+ x 1))
(c:AHpldim)
« Last Edit: September 03, 2019, 01:53:28 AM by BIGAL »
BIGAL
« Reply #9 on: September 03, 2019, 02:27:16 AM »
HasanCad this should do what you want. make sure download Multi radio buttons.lsp
; SEP 2019
(defun AHpldim  (plent / lst pt1 pt2 pt3 pt offd oldsnap dir)
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 0)
(setq offd (getdist "\nEnter offset distance  "))
(if (= but nil)(setq but 1))
(setq dir (ah:butts but "h"  '("Left or right" "Right" "Left")))
(command "copy" plent "" "0,0" "0,0")
(setvar 'filletrad 0)
(command "fillet" "p" "last")
(setq plent (entlast))
(setq lst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget plent))))
(command "erase" plent "")
(setq x 0)
(if (= dir "Right")
(setq x (+ x 1))
(setvar 'osmode oldsnap)
(AHpldim  (entsel "\nPick pline near start end"))
HasanCAD
« Reply #10 on: September 09, 2019, 03:54:05 AM »
Sorry for late in answer
Thanks BIGAL Great work
; SEP 2019
BIGAL
« Reply #11 on: September 09, 2019, 05:19:25 AM »
Not a problem, happy to help.
