Author Topic: Draw a polyline with a certain offset  (Read 1830 times)
Coder
Re: Draw a polyline with a certain offset
« Reply #15 on: August 26, 2019, 09:31:02 AM »
Can anyone translate that into codes?
roy_043
  • BricsCAD 18
« Reply #16 on: August 26, 2019, 05:19:57 PM »
Something like this can work to pick the base points on the existing polyline:
  1. (defun c:Test ( / param pt ptLst segmLst sel)
  2.   (while (setq sel (entsel "\nSelect poly near endpoints or 2x near midpoint to select segments for intersection: "))
  3.     (setq pt (osnap (cadr sel) "nea"))
  4.     (cond
  5.       ((zerop (rem param 1.0))
  6.         (setq ptLst (cons (vlax-curve-getpointatparam (car sel) param) ptLst))
  7.       )
  8.       ((> 0.3 (rem param 1.0))
  9.         (setq ptLst (cons (vlax-curve-getpointatparam (car sel) (fix param)) ptLst))
  10.       )
  11.       ((< 0.7 (rem param 1.0))
  12.         (setq ptLst (cons (vlax-curve-getpointatparam (car sel) (fix (1+ param))) ptLst))
  13.       )
  14.       (T
  15.         (setq segmLst
  16.           (cons
  17.             (list
  18.               (vlax-curve-getpointatparam (car sel) (fix param))
  19.               (vlax-curve-getpointatparam (car sel) (fix (1+ param)))
  20.             )
  21.             segmLst
  22.           )
  23.         )
  24.         (if (= 2 (length segmLst))
  25.           (progn
  26.             (setq ptLst
  27.               (cons
  28.                 (inters
  29.                   (caar segmLst)
  30.                   (cadar segmLst)
  31.                   (caadr segmLst)
  32.                   (cadadr segmLst)
  33.                   nil ; Nil=lines are infinite.
  34.                 )
  35.                 ptLst
  36.               )
  37.             )
  38.             (setq segmLst nil)
  39.           )
  40.         )
  41.       )
  42.     )
  43.   )
  44.   (setvar 'pdmode 35)
  45.   (foreach pt ptLst
  46.     (entmake
  47.       (list
  48.         '(0 . "POINT")
  49.         (cons 10 pt)
  50.       )
  51.     )
  52.   )
  53.   (princ)
  54. )
Coder
« Reply #17 on: August 26, 2019, 05:48:35 PM »
Thank you roy_043 for your time and efforts.
I could not make it to work and I did not know how to work with 2x with the message to the user!
Sorry for that, because of my lack knowledge with Lisp.
BIGAL
  • 30 + years of using Autocad
« Reply #18 on: August 27, 2019, 02:00:33 AM »
We are all on the same page one other routine I did drew a new line then filleted back onto the pre offset pline hence joining the new pline. So doing the "extend" reverses offset side then to p6 p7 a back fillet. I will try to find was a long time ago.
While we figure it out draw 1-5 then start again 9 8 7 6 fillet the two answers all done.
Have a look at screen shot the code I am trying to find filleted as it created new lines. You would need CAB's getpoint or string to flip direction L-R Yes it would use points not segments. That could be version 2.
This is like 1st ten lines. 1st code was for testing. I know lee-mac has a left or right for picked point.
  1.  (initget 6 "Swap")
  2. (while  (setq pt2 (getpoint "\nPick  start point or [Swap sides]:<"   ))
  3.        (cond
  4.           ((= (type pt2) 'LIST) (princ pt2))
  5.           ((= pt2 "Swap") (Alert "swap"))
  6.           ((= pt2 nil)(quit))
  7.      )
  8. (initget 6 "Swap")
  9. )
  10.
  1.
  2. (setq offd (getstring "R or L"))
  3. (setq pt1 (getpoint "pick 1st point"))
  4. (initget 6 "Swap")
  5. (while  (setq pt2 (getpoint "\nPick  start point or [Swap sides]:<"   ))
  6.        (cond
  7.           ((= (type pt2) 'LIST) (drawlines))
  8.           ((= pt2 "Swap") (swapr-l)) ; also calls drawlines
  9.           ((= pt2 nil)(quit))
  10.      )
  11. (initget 6 "Swap")
  12. )
  13.
« Last Edit: August 27, 2019, 03:09:36 AM by BIGAL »
BIGAL
« Reply #19 on: August 27, 2019, 06:21:45 AM »
Had a play thanks CAB for the getpoint / string
Roy_43 please feel free to add pline segments its probably though fast enough without trying to reduce pick points. It does not check for non square ends.
; draw offsets from points for random shape object making pline
; By Alan H AUG 2019
(defun ah:ploffs (/ offdir offd x pt1 pt2 pt3 oldsnap ssp)
  (defun drawline (/ ang pt3 obj)
    (setq ang (angle pt1 pt2))
    (if (= offdir "L")
      (setq pt3 (polar pt2 (+ ang (/ pi 2.0)) 10))
      (setq pt3 (polar pt2 (- ang (/ pi 2.0)) 10))
    (setvar 'osmode 0)
    (command "line" pt1 pt2 "")
    (setq obj (entlast))
    (command "offset" offd obj pt3 "")
    (setq ssp (ssadd (entlast) ssp))
    (command "erase" obj "")
    (setq pt1 pt2)
  (defun swapr-l (/)
    (if (= (strcase offdir) "L")
      (setq offdir "R")
      (setq offdir "L")
    (setvar 'osmode oldsnap)
    (setq pt1 (getpoint "\nPick  next point"))
    (setq pt2 (getpoint "\nPick  next point"))
    (drawline)
; starts here
; add side pick
  (setq oldsnap (getvar 'osmode))
  (setq ssp nil)
  (initget 6 "R L")
  (setq offdir (strcase (getstring "Right or  Left")))
  (setq offd (getreal "Enter offset distance"))
  (setq ssp (ssadd))
  (initget 6 "1 2 3 4 5 6 7 8 9 0 a b c d e f g h i j k l m n o p q r s t u v w x y z")
  (while (setq pt2 (getpoint "\nPick  next point or [S Swap sides]:<"))
      ((= (type pt2) 'LIST) (drawline))
      ((= (type pt2) 'str) (swapr-l))  ; also calls drawlines
      ((= pt2 nil) (quit))
    (initget 6 "Swap")
  (setq x 0)
  (repeat (- (sslength ssp) 1)
    (setvar 'filletrad 0)
    (command "fillet" (ssname ssp x) (ssname ssp (1+ x)))
    (setq x (1+ x))
  (setq x 0)
  (command "pedit" (entlast) "Y" "J")
    (command (ssname ssp x))
    (setq x (1+ x))
  (command "" "")
(ah:ploffs)
« Last Edit: August 27, 2019, 06:29:41 AM by BIGAL »
roy_043
  • BricsCAD 18
« Reply #20 on: August 27, 2019, 08:46:28 AM »
FWIW: Here is my attempt. For now it will only work in the WCS and for 'WCS' polylines.
  1. (defun KGA_List_LastRemove (lst)
  2.   (reverse (cdr (reverse lst)))
  3. )
  4.
  5. (defun OffsetSegments_NewSegment (poly pt dis / param ptOn vec) ; Pt is point near segment on the offset side.
  6.   (setq param (vlax-curve-getparamatpoint poly ptOn))
  7.   (setq vec (polar '(0.0 0.0 0.0) (angle ptOn pt) dis))
  8.   (list
  9.     (KGA_List_LastRemove (mapcar '+  vec (vlax-curve-getpointatparam poly (fix param))))
  10.     (KGA_List_LastRemove (mapcar '+  vec (vlax-curve-getpointatparam poly (fix (1+ param)))))
  11.   )
  12. )
  13.
  14. (defun OffsetSegments_Inters (segm1 segm2)
  15.   (apply 'inters (append segm1 segm2 '(nil)))
  16. )
  17.
  18. (defun c:OffsetSegments ( / doc dis new oldOsm poly pt ptLst segmLst)
  19.
  20.   (defun *error* (msg)
  21.     (if oldOsm (setvar 'osmode oldOsm))
  22.     (if doc (vla-endundomark doc))
  23.   )
  24.
  25.   (if
  26.     (and
  27.       (setq poly (car (entsel)))
  28.       (setq poly (vlax-ename->vla-object poly))
  29.       (= "AcDbPolyline" (vla-get-objectname poly))
  30.       (setq dis (getdist "\nOffset distance: "))
  31.     )
  32.     (progn
  33.       (setq oldOsm (getvar 'osmode))
  34.       (setvar 'osmode 0)
  35.       (while (setq pt (getpoint "\nPick offset side for each segment (close to segment) or Enter: "))
  36.         (setq ptLst (cons pt ptLst))
  37.       )
  38.       (setvar 'osmode oldOsm)
  39.       (setq segmLst
  40.         (mapcar
  41.           '(lambda (pt) (OffsetSegments_NewSegment poly pt dis))
  42.           ptLst
  43.         )
  44.       )
  45.       (setq ptLst
  46.         (apply
  47.           'append
  48.           (mapcar
  49.             '(lambda (prev cur next / int)
  50.               (cond
  51.                 ((not prev) ; Start segment: return startpoint only
  52.                   (setq int (OffsetSegments_Inters cur next))
  53.                   (if (> (distance int (car cur)) (distance int (cadr cur))) ; Distance check is not always reliable.
  54.                     (list (car cur))
  55.                     (list (cadr cur))
  56.                   )
  57.                 )
  58.                 ((not next) ; End segment: return intersection and endpoint.
  59.                   (setq int (OffsetSegments_Inters prev cur))
  60.                   (if (> (distance int (car cur)) (distance int (cadr cur)))
  61.                     (list int (car cur))
  62.                     (list int (cadr cur))
  63.                   )
  64.                 )
  65.                 (T
  66.                   (list (OffsetSegments_Inters prev cur))
  67.                 )
  68.               )
  69.             )
  70.             (cons nil segmLst)
  71.             segmLst
  72.             (append (cdr segmLst) '(nil))
  73.           )
  74.         )
  75.       )
  76.       (setq new (vla-copy poly))
  77.       (vla-put-closed new :vlax-false)
  78.       (vlax-put new 'coordinates (apply 'append ptLst))
  79.     )
  80.   )
  81.   (princ)
  82. )
« Last Edit: August 27, 2019, 08:50:07 AM by roy_043 »
Coder
« Reply #21 on: August 27, 2019, 09:39:10 AM »
Thank you BIGAL, your codes works for me.
Thank you roy_43 for your second attempt, it works very well and professionally.
Have a great day for you all.
