Author Topic: Capture animated gif by each frame one by one  (Read 1552 times)
ribarm
  • Marko Ribar, architect
« on: August 22, 2019, 06:31:07 AM »
Hi... I have ShareX with which I capture animated gifs for presentation purposes...
I was wondering : Now I have a little more complex model for presentation and with my orbit - anaglyph routine I posted in show stuff forum, my PC is very slow... So I am thinking, maybe if I hard code path of camera and capture each frame through routine one by one - like rendering that would be perfect... I know that through lisp I can put expression for exporting inside (repeat) loop, but I don't know syntax and what's more important I don't know how to gather images into single animated gif and to finally everything is presented like I captured screen with original frame rate like through ShareX...
So does someone knows this or ever tried something like so with ShareX... That program is very nice and with link provided and suggested by Michael Puckett - MP, all I can say is thank you very much my swamp friend...
M.R. on Youtube
huiz
  • Certified Prof C3D
Re: Capture animated gif by each frame one by one
« Reply #1 on: August 22, 2019, 11:00:21 AM »
I use https://www.screentogif.com/  to create animated gifs. It has an editor where you can import single images like screenshots and you can change the speed, as far as I remember per image.
And it is freeware and open source.
DeeGeeCees_V.2.0
« Reply #2 on: August 22, 2019, 11:09:20 AM »
You can create a motion path in AutoCad via _anipath and create an animated avi, mpg, or wmv file. Plenty of converters out there to get it to gif if that's what you need for final output.
ribarm
« Reply #3 on: August 22, 2019, 02:45:06 PM »
I've found some solution - I posted it here :
http://www.theswamp.org/index.php?topic=55383.msg595965#msg595965
Thanks for replies, M.R.
M.R. on Youtube
