Author Topic: xref global changes  (Read 7276 times)
notredave
Re: xref global changes
« Reply #15 on: August 26, 2019, 09:59:05 AM »
Thank you for all your replies. Here at work, when you create a directory, it is read only by default. The test drawings I had were in there and did not work. I tried it in active directory and it works! Thank you ronjonp and JeffH for the responses. I just love that trick!
Thank you,
David
