Author Topic: syntax error from simple if statement  (Read 2493 times)
vincent.r
« on: August 17, 2019, 02:40:53 AM »
(if (/= (vl-string-search "SV" do2) nil)
      (setq ndo2 (strcat "_" (substr do2 1 2) (substr do2 (strlen do2) 1)))
      (setq csvlist (cons (strcat "[_SVSIM2]" ndo2) csvlist))
      (setq ndo2 (strcat "_" (substr do2 1 3) (substr do2 (strlen do2) 1)))
Why it is giving me "; error: syntax error" ? Its strange for me. Any help will be highly appreciated.
Tharwat
  • Hypersensitive
Re: syntax error from simple if statement
« Reply #1 on: August 17, 2019, 04:13:32 AM »
Due to extra expressions ...
Dlanor
« Reply #2 on: August 17, 2019, 04:23:24 AM »
You can go with Tharwat (better solution) or eliminate the progn's entirely and run the setq's together
  1. (if (/= (vl-string-search "SV" do2) nil)
  2.   (setq ndo2 (strcat "_" (substr do2 1 2) (substr do2 (strlen do2) 1))
  3.         csvlist (cons (strcat "[_SVSIM2]" ndo2) csvlist)
  4.   )
  5.   (setq ndo2 (strcat "_" (substr do2 1 3) (substr do2 (strlen do2) 1))
  6.         csvlist (cons (strcat "[_SVSIM2]" ndo2) csvlist)
  7.   )
  8. )
  9.
« Reply #3 on: August 17, 2019, 06:13:57 AM »
Since the only difference between the then and else arguments is the number of characters supplied to the first substr expression, the code could be condensed to:
  1. (setq csvlist (cons (strcat "[_SVSIM2]_" (substr do2 1 (if (wcmatch do2 "*SV*") 2 3)) (substr do2 (strlen do2))) csvlist))
vincent.r
« Reply #4 on: August 17, 2019, 10:44:07 AM »
Thanks Tharwat and Dlanore for simple solution. Lee you are always explanative. you are rocking as usual.
I stuck in one more place. I am trying to find closest text from a another text's co-ordinate. I want to add just distance to list and not with Ename to compare closest one. Screenshot also attached.
Code -
(while (/= (sslength motorassocvfd) 0)
  (setq checkvfd (ssname motorassocvfd 0))
     (if (vl-string-search "VFD IP " (cdr (assoc 1 (entget checkvfd))) 0)
      (setq distvfd (distance (car motorcoord) (cdr (assoc 10 (entget checkvfd)))))
          (setq checkdvfd (cons distvfd checkvfd))
          (setq Enamesvfd (cons checkvfd Enamesvfd))
  (setq motorassocvfd (ssdel checkvfd motorassocvfd))
(setq found (vl-position (apply 'min checkdvfd) checkdvfd))
(setq a_vfd (cdr (assoc 1 (entget (nth found ENamesvfd)))))
Tharwat
  • Hypersensitive
« Reply #5 on: August 17, 2019, 03:22:03 PM »
Try it this way and the variable name 'closest' should obtain the shortest distance.
  1. (repeat (setq inc (sslength motorassocvfd))
  2.   (setq elst (entget (ssname motorassocvfd (setq inc (1- inc)))))
  3.   (if (vl-string-search "VFD IP " (cdr (assoc 1 elst)))
  4.     (progn
  5.       (setq distvfd (distance (car motorcoord) (cdr (assoc 10 elst))))
  6.       (if closest (if (< distvfd closest) (setq closest distvfd))
  7.         (setq closest distvfd))
  8.       )
  9.     )
  10.   )
  11.
vincent.r
« Reply #6 on: August 19, 2019, 12:07:11 AM »
Thanks Tharwat. Your code is working perfect. You are great Guru.
« Last Edit: August 19, 2019, 01:06:29 AM by vincent.r »
Tharwat
  • Hypersensitive
« Reply #7 on: August 19, 2019, 02:26:42 AM »
You're most welcome.
