Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Label and diameter lengths
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: Label and diameter lengths (Read 5956 times)
Dlanor
Bull Frog
Re: Label and diameter lengths
Reply #15 on:
August 22, 2019, 07:12:42 AM »
BigAl. I know, but i modified the code slightly to return the index as opposed to the item at index. This allowed me to access the correct item in a second list, formatting the fraction part to plug straight into the mtext.
Logged
Dlanor
http://www.theswamp.org/donate.html
BIGAL
Swamp Rat
40 + years of using Autocad
Reply #16 on:
August 23, 2019, 02:46:15 AM »
Dlannorh You can still run from 2 lines the (nth but butlst) is to push the value into the setq so if you run the (ah:butts only it will display an answer that goes no where the "but" value has already been set earlier in code so can do 1- could do the (nth but butlst) outside the defun like idx desired. But would need a list like you have done to get the text answer.
As you correctly point out the dcl uses 1 as 1st pick, a list uses 0 as 1st entry.
Code:
[Select]
(ah:butts 1 "v" a_lst)
(setq idx (1- but))
command line
(setq a_lst (list "Wire Size" "1/4" "3/8" "1/2" "3/4" "1" "1 1/4" "1 1/2" "2" "3" "4" "5"))
(LOAD "D:/Alan/Completed/Multi radio buttons.lsp")AH:BUTTS
"1 1/4"
!but
6
(setq idx (1- but))
5
Logged
Print
Pages:
1
2
All
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
