Author Topic: Change the diameter of the circle  (Read 1163 times)
myloveflyer
« on: August 12, 2019, 11:30:04 PM »
;;;by roy_043
(defun KGA_Conv_Pickset_To_ObjectList (ss / i ret)
  (if ss
    (repeat (setq i (sslength ss))
      (setq ret (cons (vlax-ename->vla-object (ssname ss (setq i (1- i)))) ret))
(defun c:Test ( / cen cirLst doc linLst radNew radOld ss)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (vla-endundomark doc)
  (vla-startundomark doc)
    (and
      (setq ss (ssget '((0 . "LINE,CIRCLE"))))
      (setq radNew (getreal "\nNew radius: "))
      (foreach obj (KGA_Conv_Pickset_To_ObjectList ss)
        (if (= "AcDbLine" (vla-get-objectname obj))
          (setq linLst
            (vl-list*
              (list (vlax-get obj 'startpoint) T obj)
              (list (vlax-get obj 'endpoint) nil obj)
              linLst
          (setq cirLst (cons obj cirLst))
      (foreach cir cirLst
        (setq cen (vlax-get cir 'center))
        (setq radOld (vla-get-radius cir))
        (vla-put-radius cir radNew)
        (foreach sub linLst
          (if (equal radOld (distance cen (car sub)) 1e-8)
              (vlax-put
                (caddr sub)
                (if (cadr sub) 'startpoint 'endpoint)
                (vlax-curve-getclosestpointto cir (car sub))
              (setq linLst (vl-remove sub linLst))
This app was written by a friend of the forum. The program now has a problem by changing the diameter of the circle to lengthen or shorten the length of the line between the circles. It is not dealing with slashes. I am not familiar with the VLAX feature. Which friend can help me solve this problem? thank you for your help!
« Last Edit: August 13, 2019, 03:18:41 AM by myloveflyer »
Never give up !
roy_043
  • BricsCAD 18
Re: Change the diameter of the circle
« Reply #1 on: August 13, 2019, 02:55:33 AM »
There are significant inaccuracies in the drawing. Change 1e-8 to 1e-2.
(Tpst_Software_UseLimit)
It seems you are selling the code that was donated to you. Food for thought...
Original topic:
https://www.theswamp.org/index.php?topic=55199.0
« Last Edit: August 13, 2019, 03:00:55 AM by roy_043 »
myloveflyer
« Reply #2 on: August 13, 2019, 03:26:42 AM »
Original topic:
Thanks,Roy!
This precision is to control the diameter of the circle. Is the accuracy in the drawing too low?
(Tpst_Software_UseLimit) This is the instructions for other users to run this program. :2funny:
« Last Edit: August 13, 2019, 03:32:27 AM by myloveflyer »
Never give up !
roy_043
  • BricsCAD 18
« Reply #3 on: August 13, 2019, 03:47:18 AM »
No. The tolerance is used to determine if line points lie on the circle.
Certainly too low for a CAD drawing.
Please start a new topic for your other problem.
myloveflyer
« Reply #4 on: August 13, 2019, 03:55:30 AM »
OK,Roy!
I will open another title.
Never give up !
myloveflyer
« Reply #5 on: August 13, 2019, 04:17:04 AM »
This drawing is out of other calculation software, so the drawing of different calculation software may not be the same as the precision control. I will pay attention to this later. Thank you Roy, you have helped me a lot!
Never give up !
