Author Topic: Filter to sum objects  (Read 720 times)
Romero
  • Mosquito
« on: August 10, 2019, 04:10:46 PM »
Hello everyone in this great forum.
Again here canning and I need your help.
I have this Lisp that gets the sum of the selected elements on the screen (line, Pline, Arc, Circle, Ellipse, 3dpoly)
  1. [code](defun c:SUMALL   (/ fList firSet entSet filOut entList totLen)
  2.
  3.
  4.   (setq fList  '((-4 . "<OR")
  5.                  (0 . "*LINE")
  6.                  (0 . "CIRCLE")
  7.                  (0 . "ARC")
  8.                  (0 . "ELLIPSE")
  9.                  (-4 . "OR>")
  10.                  (-4 . "<NOT")
  11.                  (0 . "MLINE")
  12.                  (-4 . "NOT>")
  13.                 )
  14.         filOut 0
  15.   )                                     ; end setq
  16.   (if
  17.     (not
  18.       (and
  19.         (setq firSet (ssget "_I")
  20.               entSet (ssget "_I" fList)
  21.         )                               ; end setq
  22.       )                                 ; end and
  23.     )                                   ; end not
  24.      (progn
  25.        (princ
  26.          "\n<<< Select entities to calculate total length >>> "
  27.        )
  28.        (setq entSet (ssget fList))
  29.      )                                  ; end progn
  30.      (setq filOut (- (sslength firSet) (sslength entset)))
  31.   )                                     ; end if
  32.   (if entSet
  33.     (progn
  34.       (setq entList (mapcar 'vlax-ename->vla-object
  35.                             (vl-remove-if
  36.                               'listp
  37.                               (mapcar 'cadr (ssnamex entSet))
  38.                             )
  39.                     )
  40.             totLen  (apply '+
  41.                            (mapcar '(lambda (x)
  42.                                       (vlax-curve-getDistAtParam
  43.                                         x
  44.                                         (vlax-curve-getEndParam x)
  45.                                       )
  46.                                     )
  47.                                    entList
  48.                            )
  49.                     )
  50.       )                                 ; end setq
  51.       (if (/= 0 filOut)
  52.         (princ (strcat "\n<!> "
  53.                        (itoa filout)
  54.                        " were filtered out (unsupported type)! <!>"
  55.                )
  56.         )
  57.       )                                 ; end if
  58.       (princ (strcat "\n<<< Total entities: "
  59.                      (itoa (length entList))
  60.                      ", Total length: "
  61.                      (rtos totLen)
  62.                      " >>> "
  63.              )
  64.       )
  65.     )                                   ; end progn
  66.     (princ "\n<!> Nothing selected! <!>")
  67.   )                                     ; end if
  68.   (princ)
  69. )                                       ; end of c:SUMALL
  70.
[/code]
What I would like to do is to be able to filter to obtain the desired sums only from the following objects:
- Lines
- Polylines
- Arcs
- Splines
- All
and create a repeat cycle to continue designating objects according to the selected option
I tried a cond but I don't know how to filter the selection list for my requirements.
  1. (initget "Lines Plines aRrcs Splines")
  2. (setq Opsum (getkword
  3.               "\nGet the sum of: [Lines/Plines/aRcs/Splines] <All=>: "
  4.             )
  5. )
  6.
  7.
  8. (cond ((= Opsum "Lines") (SUML))    ;;How do I filter only Lines?
  9.       ((= Opsum "Plines") (SUMPL))     ;;How do I filter only Plines?
  10.       ((= Opsum "aRcs") (SUMAR))      ;;How do I filter only Arcs?
  11.       ((= Opsum "Splines") (SUMSP))   ;;How do I filter only Spines?
  12. )
  13.
Any help will be welcome. Thank you
Re: Filter to sum objects
« Reply #1 on: August 12, 2019, 10:16:43 AM »
Try something like this:
  1. (initget "Lines Plines aRrcs Splines All")
  2. (setq opsum (getkword "\nGet the sum of: [Lines/Plines/aRcs/Splines/All] <All>: "))
  3. (cond ((= opsum "Lines") "LINE")
  4.       ;;How do I filter only Lines?
  5.       ((= opsum "Plines") "LWPOLYLINE")
  6.       ;;How do I filter only Plines?
  7.       ((= opsum "aRcs") "ARC")
  8.       ;;How do I filter only Arcs?
  9.       ((= opsum "Splines") "SPLINE")
  10.       ;;How do I filter only Spines?
  11.       ((= opsum "All") "ARC,LINE,LWPOLYLINE,SPLINE")
  12. )
  13. (setq flist  (list (cons 0 opsum))
  14.       filout 0
  15. )
Romero
  • Mosquito
« Reply #2 on: August 13, 2019, 12:20:05 PM »
  12. )
  14.       filout 0
  15. )
Hi Ron. Thank you for your response, I'm trying as you suggest, however, I'm still having problems. Do I have to delete the original list? Or just replace it?
Try something like this, but without success. I appreciate the good intention in helping the truth is that I am starting.
  1. (setq fList  '((-4 . "<OR")
  2.                (0 . "LINE")
  3.                (0 . "LWPLINE")
  4.                (0 . "ARC")
  5.                (0 . "SPLINE")
  6.                (-4 . "OR>")
  7.               )
  8.       filOut 0
  9. )
« Reply #3 on: August 13, 2019, 12:33:12 PM »
Try something like this (untested)
  1. (defun c:sumall (/ entset firset opsum totlen x)
  2.   (initget "Lines Plines aRrcs Splines All")
  3.   (setq opsum (cond ((getkword "\nGet the sum of: [Lines/Plines/aRcs/Splines/All] <All>: "))
  4.                     ("All")
  5.               )
  6.   )
  7.   (setq opsum (cond ((= opsum "Lines") "LINE")
  8.                     ;;How do I filter only Lines?
  9.                     ((= opsum "Plines") "LWPOLYLINE")
  10.                     ;;How do I filter only Plines?
  11.                     ((= opsum "aRcs") "ARC")
  12.                     ;;How do I filter only Arcs?
  13.                     ((= opsum "Splines") "SPLINE")
  14.                     ;;How do I filter only Spines?
  15.                     ((= opsum "All") "ARC,LINE,LWPOLYLINE,SPLINE")
  16.               )
  17.   )
  18.   (if (setq entset (ssget (list (cons 0 opsum))))
  19.     (if (setq totlen
  20.                (apply '+
  21.                       (mapcar '(lambda (x) (vlax-curve-getdistatparam x (vlax-curve-getendparam x)))
  22.                               (vl-remove-if 'listp (mapcar 'cadr (ssnamex entset)))
  23.                       )
  24.                )
  25.         )
  26.       (princ (strcat "\n<<< Total entities: "
  27.                      (itoa (sslength entset))
  28.                      ", Total length: "
  29.                      (rtos totlen)
  30.                      " >>> "
  31.              )
  32.       )
  33.     )
  34.     (princ "\n<!> Nothing selected! <!>")
  35.   )
  36.   (princ)
  37. )
« Last Edit: August 13, 2019, 02:08:13 PM by ronjonp »
Romero
  • Mosquito
« Reply #4 on: August 13, 2019, 12:45:19 PM »
Hi Ron Thank you very much because it works very well. I really appreciate your help.
I realized that I had an error when I wrote the initget: on line 3; but I simply removed the "r" which is too much, since it doesn't work with arcs. But now everything is fine. I will study your code to learn from it.
Another detail that I do not know how to solve is when I want to add everything, I have to type "a" to be able to designate objects. How can I make it to be predetermined and work with an enter key?
« Last Edit: August 13, 2019, 01:01:30 PM by Romero »
« Reply #5 on: August 13, 2019, 12:47:42 PM »
Sounds good .. I just quickly updated the code above to remove unnecessary calls. Also remove the conversion to val-objects since the curve function work faster with enames.
Romero
  • Mosquito
« Reply #6 on: August 13, 2019, 01:13:56 PM »
Hi Ron. Your last modification now does not work with any of the elements. Something went wrong.
« Reply #7 on: August 13, 2019, 02:05:31 PM »
Try again .. copy paste error and needed a default for 'All' :)
« Last Edit: August 13, 2019, 02:08:43 PM by ronjonp »
Romero
  • Mosquito
« Reply #8 on: August 13, 2019, 04:16:34 PM »
Thanks Ron. That has worked great. I really appreciate your help and effort. Cheers
« Reply #9 on: August 14, 2019, 11:41:01 AM »
Glad to help :)
