Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Array Help
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Array Help (Read 2892 times)
GDF
Water Moccasin
Array Help
on:
August 01, 2019, 09:58:57 AM »
I would like to get all of "SS" occurrences of the array; where "LEVELS" is the total number of the array repeat.
The code below will only pick up the first:
(setq SS (ssadd))
(command "array" (entlast) "" "r" (rtos (- LEVELS 1) 2 0) "1" flrheight)
(setq SS (ssadd (entlast) SS))
Thanks for any help
Logged
Needs a day job
Re: Array Help
Reply #1 on:
August 01, 2019, 11:47:32 AM »
Not exactly sure what you're asking for but this
should
return the number of columns and rows in an array.
Code - Auto/Visual Lisp:
[Select]
defun
c:foo
_getrc s
defun
_getrc
e
a
if
and
'ename
type
e
setq
a
cdr
member
102
"{ACAD_REACTORS"
entget
e
"ACDBASSOCDEPENDENCY"
cdr
assoc
0
setq
a
entget
cdar
a
"ACDBASSOCACTION"
cdr
assoc
0
setq
a
entget
cdr
assoc
330
a
list
cdar
cdddr
member
1
"Items"
a
cdar
cdddr
member
1
"Rows"
a
if
setq
s
ssget
0
"insert"
2
"`*U*"
foreach
e
vl
remove
if
listp
mapcar
cadr
ssnamex
s
print
_getrc e
princ
Last Edit: August 01, 2019, 11:53:47 AM by ronjonp
Logged
GDF
Water Moccasin
Re: Array Help
Reply #2 on:
August 01, 2019, 03:16:42 PM »
Thanks Ron
I'm having trouble with the selection set capturing all of the lines that make up the curtainwall in elevation.
I thought it was with the array command...now I'm not sure.
;;;;;;;;;;;;;;;;;;;;;;;; Curtainwall Elevation Function ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun draw_cwall ()...
Thanks for any guidance you can give me.
Logged
Needs a day job
Re: Array Help
Reply #3 on:
August 01, 2019, 04:35:15 PM »
Sorry Gary I'm not sure what you're trying to do.
An array is just a block so if you need to get all individual items, you could use vla-explode then have all the individual pieces to work with.
Logged
GDF
Water Moccasin
Re: Array Help
Reply #4 on:
August 01, 2019, 04:53:44 PM »
No problem...
Thanks anyway
Logged
GDF
Water Moccasin
Re: Array Help
Reply #5 on:
August 01, 2019, 06:09:18 PM »
I think I found a solution:
The
(setq ss (ssadd (entlast) ss))
was not picking up all of the linework in the selection set..
Replaced
(createblock-elev ss a))
With
(createblock-elev (ssget "X" '((0 . "LINE")(8 . "A-GLAZ-MULL"))) a))
Logged
GDF
Water Moccasin
Re: Array Help
Reply #6 on:
August 02, 2019, 09:45:50 AM »
For those following this thread, it was never an array problem. The problem was selection set gathering.
I also modified the code to replace the "Create Block Function" function with a "Raddom Generator Number" function.
Sorry for the confusion.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
Array Help
