Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
How do I store this big list into a dictionary?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How do I store this big list into a dictionary? (Read 293 times)
Grrr1337
Swamp Rat
on:
August 01, 2019, 04:48:50 AM »
Hello everyone,
I have this big, associative list of handles.. i.e.:
Code - Auto/Visual Lisp:
[Select]
defun
_Point
cdr
assoc
5
entget
entmakex
0
"POINT"
10
0.0
0.0
0.0
setq
r
; Sample to generate such list
lambda
L r
foreach
x '
"SS1"
"SS2"
"SS3"
"SS4"
"SS5"
repeat
15000
setq
L
cons
_Point
L
setq
r
cons
cons
x L
r
setq
L
nil
reverse
r
Which results into something like this -
[Select]
; Sample list to be stored into dictionaries (r) -
; (car) - SS's name ; (cdr) - List of handles
"SS1"
"26C"
"26B"
"26A"
"269"
"SS2"
"270"
"26F"
"26E"
"26D"
"SS3"
"274"
"273"
"272"
"271"
"SS4"
"278"
"277"
"276"
"275"
"SS5"
"27C"
"27B"
"27A"
"279"
Normally I use these subs from my library -
[Select]
; (IncludeDataIntoMainDic "MyXrec" nil)
; (IncludeDataIntoMainDic "MyXrec" '("Custom" 2 "data"))
; xRecName - xrecord name
; dataL - basically any type of data (usually its a list) if nil, then the xrecord will be deleted.
; http://www.theswamp.org/index.php?topic=5003.0
defun
xRecName dataL
maindic xrec
cond
not
eq
'STR
type
xRecName
prompt
\n
xRecName is not STR type."
vl-some
function
lambda
x
wcmatch
strcase
xRecName
x
"ACAD*"
"AEC*"
"Ac*"
; Being paranoid
prompt
\n
Invalid xRecord name."
t
setq
maindic
namedobjdict
if
setq
xrec
dictsearch
maindic xRecName
entdel
cdr
assoc
1
xrec
if
dataL
dictadd
maindic xRecName
entmakex
append
0
"XRECORD"
100
"AcDbXrecord"
list
cons
1
vl-prin1-to-string
dataL
; t
; cond
; defun IncludeDataIntoMainDic
; (GetDataFromMainDic "MyXrec")
defun
GetDataFromMainDic
xRecName
tmp r
and
setq
tmp
dictsearch
namedobjdict
xRecName
setq
tmp
cdr
assoc
1
tmp
setq
r
read
tmp
; and
r
; defun GetDataFromMainDic
Where the whole list of data is converted into a string and cons-ed to the DXF 1 of the xrecord entity.
But with this approach it seems that the string is too big so the character length is exceeded (it gets up to like 27617 characters and results into malformed list on input).
Logged
(apply ''((a b c)(a b c))
VovKa
Swamp Rat
Ukraine
Re: How do I store this big list into a dictionary?
Reply #1 on:
August 01, 2019, 05:40:12 AM »
variant 1. xrecord can contain multiple 1's pairs. split the list
variant 2. use vlax-ldata-put
variant 3. do not save the handles, save GROUPs
Logged
Grrr1337
Swamp Rat
Reply #2 on:
August 01, 2019, 07:22:43 AM »
Thanks VovKa,
Did the solution for variant 1:
[Select]
;| http://www.theswamp.org/index.php?topic=55350.0
(setq r
(lambda ( / _Point L r )
(defun _Point ()(cdr (assoc 5 (entget (entmakex '((0 . "POINT")(10 0.0 0.0 0.0)))))))
(foreach x '("SS1" "SS2" "SS3" "SS4" "SS5")
(repeat 15000
(setq L (cons (_Point) L))
(setq r (cons (cons x L) r))
(setq L nil)
(reverse r)
'( ; (car) - SS's name ; (cdr) - List of handles
("SS1" "26C" "26B" "26A" "269" ...)
("SS2" "270" "26F" "26E" "26D" ...)
("SS3" "274" "273" "272" "271" ...)
("SS4" "278" "277" "276" "275" ...)
("SS5" "27C" "27B" "27A" "279" ...)
(setq Dic "MyDictionary")
(_IncludeDataIntoMainDic Dic r)
(_GetDataFromMainDic Dic)
_$ (mapcar 'length (_GetDataFromMainDic "MyDictionary"))
(15001 15001 15001 15001 15001)
_$ (mapcar 'length r)
_$ (equal r (_GetDataFromMainDic "MyDictionary") 1e-1)
(_IncludeDataIntoMainDic Dic nil)
; (_IncludeDataIntoMainDic "MyDictionary" r)
defun
DicName dataL
maindic subdict dic
cond
not
eq
'STR
type
DicName
prompt
\n
DicName is not STR type."
vl-some
function
lambda
x
wcmatch
strcase
DicName
x
"ACAD*"
"AEC*"
"Ac*"
; Being paranoid
prompt
\n
Invalid Dictionary name."
t
setq
maindic
namedobjdict
if
setq
dic
dictsearch
maindic DicName
entdel
cdr
assoc
1
dic
if
dataL
progn
setq
subdict
entmakex
0
"DICTIONARY"
100
"AcDbDictionary"
setq
subdict
dictadd
maindic DicName subdict
mapcar
function
lambda
x
dictadd
subdict
car
x
entmakex
append
0
"XRECORD"
100
"AcDbXrecord"
mapcar
function
lambda
xx
cons
1
xx
cdr
x
; lambda
dataL
; if dataL
; t
; cond
; defun _IncludeDataIntoMainDic
; (_GetDataFromMainDic "MyDictionary")
defun
_GetDataFromMainDic
DicName
tmp e r
and
setq
tmp
dictsearch
namedobjdict
DicName
setq
e
cdr
assoc
1
tmp
setq
tmp
apply
function
append
mapcar
function
lambda
x
if
3
car
x
list
cdr
x
tmp
setq
r
mapcar
function
lambda
k
cons
k
mapcar
function
cdr
vl
remove
if
not
function
lambda
x
1
car
x
dictsearch
e k
tmp
; and
r
; defun _GetDataFromMainDic
Last Edit: August 01, 2019, 07:26:34 AM by Grrr1337
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
