Author Topic: Rebuild Application (.PRV) through LISP  (Read 815 times)
mailmaverick
« on: August 01, 2019, 03:30:30 AM »
I have a Visual LISP Application (.PRV) file in which multiple LISP and DCL files are mentioned.
Whenever I have to re-compile the project, I go to VLIDE Editor and do it manually (see below screenshot).
Is it possible to compile the project file through LISP ?
Thanks.
kpblc
Re: Rebuild Application (.PRV) through LISP
« Reply #1 on: August 01, 2019, 08:31:15 AM »
Impossible. And this situation won't change.
Sorry for my English.
« Reply #2 on: August 01, 2019, 09:00:54 AM »
If the vlide is loaded you can recompile via lisp. Furthermore, if you know what your doing you can create, modify prv files thru code before compiling.
Engineering Technologist CAD Automation Practitioner
cadanalyst@gmail.com http://cadanalyst.slack.com http://linkedin.com/in/cadanalyst
kpblc
« Reply #3 on: August 01, 2019, 09:29:27 AM »
You can only recompile fas (i think), not vlx.
