Author Topic: Rebuild Application (.PRV) through LISP  (Read 1813 times)
mailmaverick
« on: August 01, 2019, 03:30:30 AM »
I have a Visual LISP Application (.PRV) file in which multiple LISP and DCL files are mentioned.
Whenever I have to re-compile the project, I go to VLIDE Editor and do it manually (see below screenshot).
Is it possible to compile the project file through LISP ?
Thanks.
kpblc
Re: Rebuild Application (.PRV) through LISP
« Reply #1 on: August 01, 2019, 08:31:15 AM »
Impossible. And this situation won't change.
Sorry for my English.
« Reply #2 on: August 01, 2019, 09:00:54 AM »
If the vlide is loaded you can recompile via lisp. Furthermore, if you know what your doing you can create, modify prv files thru code before compiling.
kpblc
« Reply #3 on: August 01, 2019, 09:29:27 AM »
You can only recompile fas (i think), not vlx.
