Author Topic: Help including mtext in change text routine  (Read 7432 times)
Re: Help including mtext in change text routine
« Reply #15 on: July 30, 2019, 10:46:02 AM »
ronjonp,
I find typing CT works alot faster. CT is automatically loaded. I don't have to load CT every time. I'm old school, lol. Also, this CT routine works on MTEXT. I just like it a lot better. I'm just curious why it isn't working on that particular instance.
Thank you,
David
What version of AutoCAD are you on? The find and replace has many more options than this lisp as well as wildcard searches. It will work on many more objects as well. ( MLEADERS ATTRIBUTES DIMENSIONS etc.. )
I understand being old school ( I'm a command line guy ) but sometimes there are just better ways to do things :)
« Reply #16 on: July 30, 2019, 10:55:05 AM »
Consider something like this .. written quickly and not tested.
  1. (defun c:ct (/ f s new old str)
  2.   (if (and (setq s (ssget ":L" '((0 . "MTEXT,TEXT"))))
  3.            (setq old (getstring "\nOld string: " t))
  4.            (setq new (getstring "\nNew string: " t))
  5.       )
  6.     (foreach o (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
  7.       (setq str (vla-get-textstring o))
  8.       (setq f nil)
  9.       ;; I'm pretty sure this search and replace method has a bug .. Roy?
  10.       (while (vl-string-search old str) (setq str (vl-string-subst new old str)) (setq f t))
  11.       (and f (vla-put-textstring o str))
  12.     )
  13.   )
  14.   (princ)
  15. )
  16.
notredave
« Reply #17 on: July 30, 2019, 11:12:39 AM »
ronjonp,
Thank you very much for your efforts. I tried it but I get a spinning windows circle after I type in new text, waiting for it to change. Oh well, don't worry about it but thank you very much for replying.
David
« Reply #18 on: July 30, 2019, 11:27:27 AM »
ronjonp,
David
Strange .. what are your search strings?
notredave
« Reply #19 on: July 30, 2019, 11:34:01 AM »
* RING (asterisk space)
trying to change it to *(asterisk without the space)
That's when I get the windows wheel spinning
« Reply #20 on: July 30, 2019, 11:36:31 AM »
On the same sample drawing? It works here.
Try this version .. has a check to make sure we're not stuck in a loop.
  1. (defun c:ct (/ a i f s new old str)
  5.       )
  8.       (setq f nil)
  9.       (while (and (setq i (vl-string-search old str)) (not a))
  10.         (setq str (vl-string-subst new old str))
  11.         ;; Make sure we're not stuck in a loop
  12.         (setq a (= (vl-string-search old str) i))
  13.         (setq f t)
  14.       )
  15.       (and f (vla-put-textstring o str))
  16.     )
  17.   )
  18.   (princ)
  19. )
« Last Edit: July 30, 2019, 11:41:50 AM by ronjonp »
notredave
« Reply #21 on: July 30, 2019, 11:43:52 AM »
This is very strange to me.
If I type in to change * R TO R, it works
If i type * (space) to *(no space) it doesn't change it.
But, I will have to say your code is a lot cleaner and shorter than mine. I love it!
Thank you much,
David
« Reply #22 on: July 30, 2019, 11:52:21 AM »
Thank you much,
David
It's because the trailing spaces get dropped in the getstring input "* ". That's why you got stuck in a loop before.
This version checks for equal new and old strings .. give it a try! :)
  5.       )
  6.     (if (= old new)
  7.       (princ (strcat "\nOld '" old "' is same as new '" new "' buh bye!"))
  8.       (foreach o (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
  9.         (setq str (vla-get-textstring o))
  10.         (setq f nil)
  11.         (while (and (setq i (vl-string-search old str)) (not a))
  12.           (setq str (vl-string-subst new old str))
  13.           ;; Make sure we're not stuck in a loop
  14.           (or (setq a (= (vl-string-search old str) i)) (setq f t))
  15.         )
  16.         (and f (vla-put-textstring o str))
  17.       )
  18.     )
  19.   )
  20.   (princ)
  21. )
« Last Edit: July 30, 2019, 12:00:08 PM by ronjonp »
notredave
« Reply #23 on: July 30, 2019, 12:06:42 PM »
ronjonp,
How do you create a gif file to show you what's it doing to me?
notredave
« Reply #24 on: July 30, 2019, 12:20:35 PM »
See gif attached.
« Reply #25 on: July 30, 2019, 01:03:10 PM »
See gif attached.
It's something in the GETSTRING input/output which I have no control over. It's removing trailing spaces ( same results here ).
FIND works  :-P
« Last Edit: July 30, 2019, 01:06:24 PM by ronjonp »
notredave
« Reply #26 on: July 30, 2019, 01:16:35 PM »
Thank you very much for your personal time on this. I appreciate you.
David
« Reply #27 on: July 30, 2019, 01:48:00 PM »
David
Glad to help! :)
roy_043
  • BricsCAD 18
« Reply #28 on: July 30, 2019, 02:02:02 PM »
@ronjonp:
Indeed we have discussed string substitution code before. Problems can occur if the new sub-string contains the old sub-string. Your last version of c:CT will catch some cases but not "apple" => "more apples".
I would use something like this:
; (String_Subst "aabbaacc" "aa" "xx")   => "xxbbxxcc"
; (String_Subst "aabbaacc" "aa" "xxaa") => "xxaabbxxaacc"
(defun String_Subst (str old new / idx)
  (setq idx 0)
  (while (setq idx (vl-string-search old str idx))
    (setq str (vl-string-subst new old str idx))
    (setq idx (+ idx (strlen new)))
  str
« Reply #29 on: July 30, 2019, 02:41:01 PM »
@ronjonp:
  (setq idx 0)
  str
Thanks for the example .. I knew we had chatted about it a while back but could not find the thread. *cheers*
