BIGAL,
Thank you very much for the response and I tried your routine and it does work but backwards to what I'm used to. With mine, I type in "ct" which is embedded in my main lisp routine as part of my many other routines and i can do crossing on whole drawing if I wanted to, over lines, attributes, etc and when I hit return, I input old value and new value and it changes applicable text. If there is a way to modify the one I posted to be able to change mtext also, that would be awesome. I don't like to use "find" because you have to make sure you select upper right icon to select part of drawing you want which the "ct" routine does that. I hope I didn't make you mad, not my intention BIGAL.
Thank you,
David
