Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Layout to Model
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Layout to Model (Read 2252 times)
pedroantonio
Guest
Layout to Model
on:
July 21, 2019, 10:25:55 AM »
Hi. I am using Lee Mac Viewport Outline lisp
http://www.lee-mac.com/vpoutline.html
, to insert viewport outline in model space. Is any way to inset all the layout in model space in correct scale and position and not only the outline of the viewport ?
Logged
pedroantonio
Guest
Re: Layout to Model
Reply #1 on:
July 21, 2019, 11:04:50 AM »
I have this lisp file but export everything in wrong position with wrong scale.I want to keep the viewport scale and the correct coordinate position, like Viewport Outline
Code - Auto/Visual Lisp:
[Select]
defun
c:test
BASE LST OLD_DIA
setq
old_dia
getvar
'FILEDIA
base
strcat
getvar
'DWGPREFIX
vl-filename-base
getvar
'DWGNAME
setvar
'FILEDIA
0
setq
lst
layoutlist
foreach
l lst
command
"_.ctab"
l
"exportlayout"
strcat
base
l
setvar
'FILEDIA old_dia
princ
Any ideas?
Logged
pedroantonio
Guest
Re: Layout to Model
Reply #2 on:
July 22, 2019, 03:47:05 AM »
Is it posible to Convert Layout to Model Space by viewport scale , like Lee Mac Viewport Outline lisp
thanks
Logged
seksone
Mosquito
Re: Layout to Model
Reply #3 on:
July 22, 2019, 07:52:21 AM »
do you know the command _chspace?
maybe that is the trick.
Logged
pedroantonio
Guest
Re: Layout to Model
Reply #4 on:
July 22, 2019, 05:14:50 PM »
Yes i know this command, but insert the layouts in the wrong coordinates with wrong scale
Logged
pedroantonio
Guest
Re: Layout to Model
Reply #5 on:
July 24, 2019, 06:27:59 AM »
seksone you are right _chspace command works fine
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
Layout to Model
