Author Topic: Where does autocad save the different variable settings?  (Read 3131 times)
nobody
  • .net stuff
« on: July 19, 2019, 06:50:02 PM »
Hey all,
Where does autocad store/save the different variable settings?
dgorsman
Re: Where does autocad save the different variable settings?
« Reply #1 on: July 21, 2019, 01:50:11 AM »
In different places, some in the DWG file, some in the registry, and some are not stored at all.  Look in the documentation,  each system variable will list where (and if) it is stored.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
57gmc
« Reply #2 on: July 22, 2019, 01:46:35 PM »
Also, besides the help, SYSVDLG lists each variable and where it is stored.
nobody
  • .net stuff
« Reply #3 on: July 23, 2019, 11:37:52 AM »
Thank you
« Reply #4 on: July 25, 2019, 12:24:48 PM »
This is a great resource  http://www.hyperpics.com/system_variables/index.asp
If you are registered you can click on each variable & learn where it is stored & much more.
nobody
  • .net stuff
« Reply #5 on: July 26, 2019, 04:57:10 PM »
Thanks @CAB
HasanCAD
« Reply #6 on: July 29, 2019, 03:20:48 AM »
And if Express installed
try this command
_.sysvdlg
