I have a problem with the insert of a block that differs in (1) sheet. I am using a Lisp routine to create drawings that inserts certain blocks at a typical point in each drawing. After having inserting the first block, it then inserts a second block at another typical pt. When each drawing is finished all of them are correct except for 1 drawing that uses a certain block. The second block is offset. Also, the drawing that is incorrect, when it is created the display is zoomed out. Whereas the others are zoomed to extents. I wondered if anyone could help or at least give directions as to what might be happening.
