Author Topic: Display driver error while working in AutoCAD  (Read 2612 times)
dubb
« on: July 16, 2019, 04:02:52 PM »
This sort of a rant but This solution has got to be one of the worst solutions I have for an ongoing issue.
Solution #7 Doesn't apply
Solution #6 Reducing Graphicsconfig, linesmoothing, doesn't look visually accurate when designing 2 polylines
Solution #4 Reducing hatch pattern scales will make hatches irrelevant such that it disappears or too large.
Solution #2 reducing hpmaxlines not an option same as #4.
I have already downloaded the latest display driver. Haven't reinstalled visual c++. Issues submitted to AutoDesk
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Crashing-with-drawings-that-contain-large-or-dense-hatch-objects.html
ChrisCarlson
Re: Display driver error while working in AutoCAD
« Reply #1 on: July 16, 2019, 05:04:22 PM »
Instead of the latest driver, check against Autodesk's website for the latest "Certified" driver. In the past I had to use a version that was substantially older just to keep ACAD from crashing with hatches that appeared solid when zoomed out.
dubb
« Reply #2 on: July 16, 2019, 06:19:40 PM »
I'll try that. Further looking into the graphics hardware. My my graphics card is not listed in as certified.
https://knowledge.autodesk.com/certified-graphics-hardware
rkmcswain
« Reply #3 on: July 17, 2019, 09:00:16 AM »
Quote from: dubb
That's probably it. AutoCAD is pretty finicky about the display adapter and driver.
