Author Topic: Re: List of numbers to String  (Read 2498 times)
Dilan
« on: July 12, 2019, 08:44:02 PM »
Hello
I have a list :
(1 74678.6 53741.6 0.0)How do i convert it to value :
"1 74678.6 53741.6 0.0"
Tell me please....
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #1 on: July 12, 2019, 10:04:42 PM »
Ugly, but it should work for you with the different types of numbers
  1.
  2. (setq xx '(1 74678.6 53741.6 0.0))
  3. (setq result
  4.        (vl-string-subst  ""  ")"
  5.          (vl-string-subst "" "(" (vl-prin1-to-string xx))
  6.        )
  7. )
  8.
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
  • SuperMod
« Reply #2 on: July 12, 2019, 10:08:39 PM »
Dilan,
It's better not to post in old threads with topics that are slightly different.
Dilan
« Reply #3 on: July 12, 2019, 11:55:49 PM »
Dilan,
thanks for the help, kdub.
I will remember your comment about posting messages in old topics.
Thanks again.
Grrr1337
Re: Re: List of numbers to String
« Reply #4 on: July 13, 2019, 06:59:08 AM »
  1. (setq itm '(1 74678.6 53741.6 0.0))
  2. (setq result
  3.   (eval
  4.     (append
  5.       '('((x a b c d) (strcat a x b x c x d)))
  6.       '(" ")
  7.       (mapcar 'vl-prin1-to-string itm)
  8.     )
  9.   )
  10. )
(apply ''((a b c)(a b c))
vevo.bg
roy_043
  • BricsCAD 18
« Reply #5 on: July 13, 2019, 10:41:24 AM »
  1. (setq xx '(1 74678.6 53741.6 0.0))
kdub_nz
  • SuperMod
« Reply #6 on: July 13, 2019, 05:35:52 PM »
