Author Topic: [Solved] Acad: 50% CPU when hanging; 9% CPU when working  (Read 2268 times)
Peter2
« on: July 08, 2019, 06:42:15 AM »
(This happened on Map 2018; but I suppose this is a basic question).
AFAIK AutoCAD uses is not "multi-threading", so it uses only one thread. My PC has 6 Cores and 12 Threads, and when I run the Cadalyst-benchmark, I get a CPU of approx. 8% (100%Total / 12cores = 8% full load of one core).
See Picture.
When it "began to hang" in MAP 2018 - I can still work, but I see that the CPU is going to 20-25%. Continuing work, and then close database and close drawing - so Acad should to absolutely nothing - I have a stable CPU load of 50%, spread over all cores.
See other picture.
How can this happen? 50% on a one-thread-application?
Does it happen to others too?
« Last Edit: July 10, 2019, 04:31:39 AM by Peter2 »
Peter
AutoCAD Map 3D 2018 German (so some technical terms will be badly retranslated to English)
BricsCAD V19
rkmcswain
Re: Acad: 50% CPU when hanging; 9% CPU when working
« Reply #1 on: July 08, 2019, 08:27:04 AM »
Who knows. I doubt anyone at Autodesk could even answer this.
There are certain functions that are multi-threaded in ACAD however, such as rendering and Regen.
This document says only 2D regens....
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Support-for-multi-core-processors-with-AutoCAD.html
while this Autodesk employee says it's for 2D regens _and_ rendering:
https://forums.autodesk.com/t5/autocad-forum/new-multithread-multi-core-support/m-p/8718450#M975483
dgorsman
« Reply #2 on: July 08, 2019, 11:04:04 AM »
Change to something like System Monitor to look at actual activity.  Seeing as this is Map3D there may be extra daemons/database "stuff" involved that doesn't apply to vanilla.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
Peter2
« Reply #3 on: July 10, 2019, 03:59:14 AM »
Just to add more information: I found that when Acad hangs (run with 16.6% CPU load) I have
- 8.33% CPU from acad.exe
- 8.33% CPU from AdDownloaderCore.dll
See image
EDIT:
Seem to be solved. Searching for AdDownloaderCore.dll brings a lot of results, starting from 2012 until 2018.
Solution:
rename the DLL
Links:
http://docs.autodesk.com/MAP/2013/ENU/files/readme-map.htm
https://forums.autodesk.com/t5/autocad-forum/autocad-uses-100-cpu-core/m-p/8402750/highlight/false
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD-does-not-respond-waiting-for-svchost-exe-process-in-Resource-Monitor.html
« Last Edit: July 10, 2019, 04:30:20 AM by Peter2 »
Peter
BricsCAD V19
rkmcswain
Re: [Solved] Acad: 50% CPU when hanging; 9% CPU when working
« Reply #4 on: July 10, 2019, 07:25:22 AM »
@Peter2 - thanks for this valuable information, the screen shot, and the links!
MSTG007
« Reply #5 on: July 10, 2019, 02:00:06 PM »
Thank you so much for sharing that. Its amazing what you find. lol
Civil3D 2020
Peter2
« Reply #6 on: July 11, 2019, 02:56:35 AM »
Solution:
rename the DLL
Maybe NOT solved.
Today morning, when starting the PC, a setup-routine for AutoCAD popped up.
I cancelled it, rebooted - same game.
I cancelled again, gave the DLL its original name, rebooted - and the  setup does not appear.
So maybe the diagnosis is OK, but not the therapy ...
Peter
BricsCAD V19
