Author Topic: Seperate attributed blocks within a dymnamic block  (Read 5962 times)
jlogan02
« on: July 05, 2019, 06:02:42 PM »
I've created two visibility states for two different borders.
One Vis state has a title block with attributes and an approval stamp with attributes. The other does not
As a user, I want to be able to edit the title block attribute without seeing any of the approval stamp attributes and visa versa.
What I end up getting is one large attribute edit dialog that includes everything.
I'm pretty sure it's a process thing.
Here's what I'm doing...
Open a blank drawing
Open Block Editor
Insert desired objects and blocks (attributes=Locked Position to "YES") All attributes have separate tag names.
Create Vis States
Assign objects to Vis States
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
jlogan02
Re: Seperate attributed blocks within a dymnamic block
« Reply #1 on: July 05, 2019, 06:04:40 PM »
Forgot to attach the block!!
J. Logan
ACAD 2018
jlogan02
« Reply #2 on: July 05, 2019, 06:50:02 PM »
I've kinda figured it out.
Attributes cannot exist together in the same Vis State. I had to create a Vis State for the Title block and a Vis State for the Approval Stamp.
All is right with the world.
Looking at the test block it seems promising.
Real world though, I'm not getting the results I want. Since the title block will exist in all Vis States it may be that I don't want the title block to be part of the dynamic block. I haven't tested that theory yet.
J. Logan
ACAD 2018
