Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
vlr-owner-remove doesn't work
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: vlr-owner-remove doesn't work (Read 1860 times)
Grrr1337
Swamp Rat
WWW
on:
July 03, 2019, 10:39:19 AM »
Hi guys,
I rarely deal with object reactors, so today decided to do some practice by utilising the vlr-owner* functions.. and this got me confused
From the docs :
Removes an object from the list of owners of an object reactor
Manual practice/testing on a object reactor:
Code - Auto/Visual Lisp:
[Select]
_$
defun
CB:ObjReactor
ownr rtr args
princ
\n
Reaction occured"
; defun
CB:OBJREACTOR
_$
foreach
rtr
cdar
vlr-reactors
VLR-Object-Reactor
if
"test"
vlr-data
rtr
vlr-remove
rtr
nil
_$
setq
TheReactor
vlr-object-reactor
; Selected a LWPOLYLINE and a CIRCLE
lambda
SS i L
if
setq
SS
ssget
"_:L-I"
repeat
setq
i
sslength
SS
setq
L
cons
vlax
ename
vla-object
ssname
SS
setq
i
1-
i
L
reverse
L
; lambda
"test"
mapcar
lambda
x
cons
x 'CB:ObjReactor
vlr-reaction-names
VLR-Object-Reactor
; vlr-object-reactor
; setq *TheReactor*
VLR
Object
Reactor
_$
vlr-owners
TheReactor
VLA-OBJECT
IAcadLWPolyline 000000ed9a689968
VLA-OBJECT
IAcadCircle 000000edf6e32c18
_$
; Selected an ARC
lambda
SS i
if
setq
SS
ssget
"_:L-I"
progn
repeat
setq
i
sslength
SS
vlr-owner-add
TheReactor
vlax
ename
vla-object
ssname
SS
setq
i
1-
i
vlr-owners
TheReactor
; lambda
Reaction occured
VLA-OBJECT
IAcadArc 000000ed9da0f528
VLA-OBJECT
VLA-OBJECT
_$
; Selected the ARC and the CIRCLE
lambda
SS i
if
setq
SS
ssget
"_:L-I"
progn
repeat
setq
i
sslength
SS
vlr-owner-remove
TheReactor
vlax
ename
vla-object
ssname
SS
setq
i
1-
i
vlr-owners
TheReactor
; lambda
VLA-OBJECT
VLA-OBJECT
VLA-OBJECT
_$
vlr-owners
TheReactor
VLA-OBJECT
VLA-OBJECT
VLA-OBJECT
_$
foreach
x
vlr-owners
TheReactor
; Alternative try
if
member
vla-get-ObjectName
x
"AcDbArc"
"AcDbCircle"
vlr-owner-remove
TheReactor
x
VLA-OBJECT
_$
vlr-owners
TheReactor
; the alternative doesn't work -
VLA-OBJECT
VLA-OBJECT
VLA-OBJECT
One could try it by himself, I'm with ACAD 2017 BTW.
Logged
(apply ''((a b c)(a b c))
vevo.bg
ribarm
Gator
Marko Ribar, architect
WWW
Re: vlr-owner-remove doesn't work
Reply #1 on:
July 05, 2019, 04:51:34 AM »
Tested on A2018... The same thing...
[Select]
_$
defun
CB:ObjReactor
ownr rtr args
_
princ
\n
Reaction occured"
_
CB:OBJREACTOR
_$
foreach
rtr
cdar
vlr-reactors
VLR-Object-Reactor
if
"test"
vlr-data
rtr
vlr-remove
rtr
nil
_$
setq
TheReactor
_
vlr-object-reactor
_
_
lambda
SS i L
_
if
setq
SS
ssget
"_:L-I"
_
repeat
setq
i
sslength
SS
_
setq
L
cons
vlax
ename
vla-object
ssname
SS
setq
i
1-
i
L
_
_
_
reverse
L
_
; lambda
_
_
"test"
_
mapcar
lambda
x
cons
x 'CB:ObjReactor
vlr-reaction-names
VLR-Object-Reactor
_
_
; setq *TheReactor*
VLR
Object
Reactor
_$
vlr-owners
TheReactor
VLA-OBJECT
IAcadLWPolyline 0000028ce2f9f738
VLA-OBJECT
IAcadCircle 0000028ce2f9f138
_$
; Selected an ARC
_
lambda
SS i
_
if
setq
SS
ssget
"_:L-I"
_
progn
_
repeat
setq
i
sslength
SS
_
vlr-owner-add
TheReactor
vlax
ename
vla-object
ssname
SS
setq
i
1-
i
_
_
vlr-owners
TheReactor
_
_
_
; lambda
_
Reaction occured
VLA-OBJECT
IAcadArc 0000028ce2de18c8
VLA-OBJECT
VLA-OBJECT
_$
_
lambda
SS i
_
if
setq
SS
ssget
"_:L-I"
_
progn
_
repeat
setq
i
sslength
SS
_
vlr-owner-remove
TheReactor
vlax
ename
vla-object
ssname
SS
setq
i
1-
i
_
_
vlr-owners
TheReactor
_
_
_
; lambda
_
VLA-OBJECT
VLA-OBJECT
VLA-OBJECT
_$
vlr-owners
TheReactor
VLA-OBJECT
VLA-OBJECT
VLA-OBJECT
_$
foreach
x
vlr-owners
TheReactor
; Alternative try
_
if
member
vla-get-ObjectName
x
"AcDbArc"
"AcDbCircle"
_
vlr-owner-remove
TheReactor
x
_
_
VLA-OBJECT
_$
vlr-owners
TheReactor
VLA-OBJECT
VLA-OBJECT
VLA-OBJECT
_$
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
ribarm
Gator
WWW
Reply #2 on:
July 05, 2019, 07:27:40 AM »
All I could find out is to reconstruct reactor :
[Select]
defun
CB:ObjReactor
owner reactor lstename
princ
\n
Reaction occured"
setq
TheReactor
vlr-object-reactor
lambda
SS i L
if
setq
SS
ssget
"_:L-I"
repeat
setq
i
sslength
SS
setq
L
cons
vlax
ename
vla-object
ssname
SS
setq
i
1-
i
L
reverse
L
"test"
mapcar
lambda
x
cons
x 'CB:ObjReactor
vlr-reaction-names
VLR-Object-Reactor
princ
\n
princ
vlr-owners
TheReactor
defun
_setq
reactor
vlr-owner-remove
reactor owner
owners data typ reactions
setq
owners
vlr-owners
reactor
setq
owners
vl-remove
owner owners
setq
data
vlr-data
reactor
setq
typ
vlr
type
reactor
if
type
data
'str
setq
reactions
vlr-reactions
reactor
vlr-remove
reactor
if
type
data
'str
eval
read
substr
vl-prin1-to-string
typ
2
owners data reactions
eval
read
substr
vl-prin1-to-string
typ
2
owners data
setq
TheReactor
_setq
reactor
vlr-owner-remove
TheReactor
setq
owner
car
vlr-owners
TheReactor
princ
\n
princ
vlr-owners
TheReactor
vlr-owner-add
TheReactor
owner
princ
\n
princ
vlr-owners
TheReactor
princ
So if you firstly selected 3 entities, *TheReactor* should have after calling sub 2 owners, as first one is removed and then at the end global variable *owner* is added with (vlr-owner-add) function which works well...
HTH., M.R.
Last Edit: July 05, 2019, 10:20:42 AM by ribarm
Logged
Marko Ribar, d.i.a.
M.R. on Youtube
ribarm
Gator
WWW
Reply #3 on:
July 05, 2019, 10:39:27 AM »
I've updated sub function to be better... No need for callback function as argument... It's just like it should be : reactor and owner as arguments...
Regards, M.R.
Logged
Marko Ribar, d.i.a.
M.R. on Youtube
Grrr1337
Swamp Rat
WWW
Reply #4 on:
July 06, 2019, 09:18:35 PM »
Thanks for confirming, Marco -
Looks like there are few threads over here, regarding this
vlr-owners-remove
function, where I participated but haven't noticed that this function actually doesn't work.
http://www.theswamp.org/index.php?topic=52995.msg578082#msg578082
http://www.theswamp.org/index.php?topic=52970.msg577851#msg577851
http://www.theswamp.org/index.php?topic=53048.msg578824#msg578824
So for my other test program, I had to substitute my previous code block..
[Select]
; vlr-owner-remove doesn't work - http://www.theswamp.org/index.php?topic=55299.0
lambda
SS rtr
if
and
setq
rtr
vl-some
function
lambda
x
if
rtrnm
vlr-data
x
x
cdar
vlr-reactors
VLR-Object-Reactor
setq
SS
ssget
"_:L-I"
lambda
SS
i
repeat
setq
i
sslength
SS
vlr-owner-remove
rtr
vlax
ename
vla-object
ssname
SS
setq
i
1-
i
; lambda
SS
; if SS
; lambda
..with this one..
[Select]
; vlr-owner-remove doesn't work, hence redefine the reactor
lambda
rtr notifiers SS
if
and
setq
rtr
vl-some
function
lambda
x
if
rtrnm
vlr-data
x
x
cdar
vlr-reactors
VLR-Object-Reactor
setq
notifiers
vlr-owners
rtr
setq
SS
ssget
"_:L-I"
progn
foreach
rtr
cdar
vlr-reactors
VLR-Object-Reactor
if
rtrnm
vlr-data
rtr
vlr-remove
rtr
vlr-object-reactor
vl
remove
if
lambda
x
ssmemb
vlax
vla
object
ename x
SS
notifiers
rtrnm
mapcar
lambda
x
cons
x 'CB:ObjReactor
vlr-reaction-names
VLR-Object-Reactor
; progn
; if SS
; lambda
Basically reconstructing the reactor like you did - although the point is regarding the vlr-owners-remove function.
Logged
vevo.bg
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
