Author Topic: Insert block with attributes Lisp,Autocad 2020  (Read 3901 times)
adham7
  • Mosquito
« on: July 01, 2019, 04:06:24 AM »
Hello, I have a lisp to insert block with attributes, it works will in autocad 2019,but didn't work in autocad 2020
(Command "-INSERT" "COORD" "390058.877,2880253.783,9.22" "1" "1" "0" "BM-1" "" "" "" )
Thanks...
Marc'Antonio Alessi
  • Marco
Re: Insert block with attributes Lisp,Autocad 2020
« Reply #1 on: July 01, 2019, 04:20:49 AM »
See values of:
Comando: ATTREQ
Digitare nuovo valore per ATTREQ <0>: 1
Comando: ATTDIA
Digitare nuovo valore per ATTDIA <1>: 0
Show command line:
Comando: (Command "_-INSERT" "COORD" "390058.877,2880253.783,9.22" "1" "1" "0" "BM-1" "" ""); < one attrib test
nil
adham7
  • Mosquito
« Reply #2 on: July 01, 2019, 04:37:55 AM »
See values of:
Comando: ATTREQ
Comando: ATTDIA
Show command line:
nil
Thank You,It works will
