Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Edit path type for xrefs via lisp
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Edit path type for xrefs via lisp (Read 3546 times)
densan
Mosquito
on:
June 20, 2019, 01:33:10 PM »
Hello, I need some help understanding what to edit in the code below.
I have to set the path of attached xrefs to NONE (familiar with reference manager tool, lisp needed for automation purposes).
If I want to set the xref path type to none, do I still need Lee's function section?
It cannot be as simple as to edit line 16, rigth?
It doesn't have to be this code in particular, but looking through various forums and testing multiple sets of code, this one was the closest to what I need.
Any help would be appreciated, thank you.
Code - Auto/Visual Lisp:
[Select]
;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/xref-relative-path-lisp/td-p/4792859
;; Changes xref path types from absolute to relative
;; Functions by:
;; Henrique Moreira da Silva - 2014
;; Lee Mac - 2011
defun
c:rpath
vlax-For
blk
vla-Get-Blocks
vla-Get-ActiveDocument
vlax-Get-Acad-Object
if
and
vla-Get-IsXref
blk
:vlax-True
vl-string-search
vla-get-path
blk
0
vla-put-path
blk
LM:XRef:Full
Relative
vl-string-right-trim
getvar
'DWGPREFIX
use
"dwgname"
in this line?
vla-get-path
blk
vl-cmdf
"_.qsave"
princ
;;-------------=={ Full Path to Relative Path }==-------------;;
;; Converts a Full XRef path to a Relative Path. ;;
;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;;
;; Arguments: ;;
;; dir - Directory of the Drawing in which the Xref resides ;;
;; path - Full Xref Path ;;
;; Returns: Relative XRef Path ;;
defun
LM:XRef:Full
Relative
dir path
p q
setq
dir
dir
cond
and
setq
p
vl-string-position
58
dir
setq
q
vl-string-position
58
path
not
eq
strcase
substr
dir
1
p
strcase
substr
path
1
q
path
and
setq
p
vl-string-position
92
dir
setq
q
vl-string-position
92
path
eq
strcase
substr
dir
1
p
strcase
substr
path
1
q
LM:Xref:Full
Relative
substr
dir
2
p
substr
path
2
q
and
setq
q
vl-string-position
92
path
eq
strcase
dir
strcase
substr
path
1
q
strcat
substr
path
2
q
eq
dir
path
setq
p
vl-string-position
92
dir
LM:Xref:Full
Relative
substr
dir
2
p
strcat
path
LM:Xref:Full
Relative
strcat
path
Logged
Seagull
London, England
WWW
Re: Edit path type for xrefs via lisp
Reply #1 on:
June 20, 2019, 02:45:31 PM »
This should be sufficient -
[Select]
defun
c:xrnone
vlax-for
b
vla-get-blocks
vla-get-activedocument
vlax-get-acad-object
if
:vlax-true
vla-get-isxref
b
vla-put-path
b
apply
strcat
cdr
fnsplitl
vla-get-path
b
princ
vl-load-com
princ
Logged
Lee Mac Programming
Twitter
Exchange App Store
densan
Mosquito
Reply #2 on:
June 20, 2019, 04:13:23 PM »
There are not enough thanks to Lee for all the help.
I now know the answer to my question.
...(apply 'strcat (cdr (fnsplitl (vla-get-path b))))...
;; pass all but first item from fnsplitl (....
Thank you very much
Logged
Seagull
London, England
WWW
Reply #3 on:
June 20, 2019, 04:31:11 PM »
Precisely
You're most welcome.
Logged
Lee Mac Programming
Twitter
Exchange App Store
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
