Author Topic: There is a Dynamo section :-)  (Read 7248 times)
huiz
  • Certified Prof C3D
« on: June 19, 2019, 09:49:48 AM »
I was wondering if there was a Dynamo section yet here, since Dynamo for Civil 3D is available. And as a surprise, there is such a section!  :yay!:
Only the description is not correct, it is not just for Revit.
I spent a few weeks to learn Dynamo and at the moment I develop some Zero Nodes in C#. Anyone else who is programming modules for Dynamo for Civil 3D?
lamarn
Re: There is a Dynamo section :-)
« Reply #1 on: October 04, 2019, 05:12:43 AM »
Hi Anton,
Correct,  of course Revit and its marketeers where the first ones..
Dut Dynamo could serve them all. Good.
Very curious what can be done with Dynamo for DWG that is beyond Lisp.
Anything in regard to better working with Autodesk software (interopability) is welcome.
My hope is on user of software, not platform creators
« Last Edit: October 04, 2019, 05:20:19 AM by lamarn »
jtm2020hyo
« Reply #2 on: April 14, 2020, 06:06:02 PM »
Hi Anton,
can you share any DWG example?
lamarn
« Reply #3 on: April 15, 2020, 02:05:33 AM »
You will probably find more like minded at
https://forum.dynamobim.com
Peter2
« Reply #4 on: November 03, 2020, 04:53:00 AM »
@lamarn
on your picture there is manually added "AutoCAD" to the list. I'm surprised that pure Autocad also supports Dynamo?
Peter
AutoCAD Map 3D 2018 German (so some technical terms will be badly retranslated to English)
BricsCAD V21
huiz
« Reply #5 on: November 03, 2020, 10:53:15 AM »
@lamarn
It doesn't. You can create or read from AutoCAD objects but only in the Civil 3D environment.
kozmos
« Reply #6 on: November 14, 2020, 09:09:24 PM »
@lamarn
you can use my dynamo package linkdwg or linkdwg2 to operate active autocad from dynamocore.
KozMos Inc.
lamarn
« Reply #7 on: November 23, 2020, 02:46:08 PM »
@lamarn
Autodesk marketing at work! :( boooo Autodesk
