Author Topic: Double-Click return attribute  (Read 2467 times)
donnieworld
  • BricsCAD Fan
« on: June 18, 2019, 08:34:15 PM »
I've successfully customized the CUI to run my lisp routine when the user double-clicks on an attribute. I need to change the lisp routine to select the attribute they double-clicked on? Everything I try returns the block, not the specific attribute?
I expected something very simple like this to work ...
(setq ss1 (ssget "i:n")) or (setq ss1 (ssget "i:v"))
Thanks in advance :-)
Donald Broussard
Fusion Engineering and Technology
BIGAL
  • 40 + years of using Autocad
Re: Double-Click return attribute
« Reply #1 on: June 19, 2019, 12:28:58 AM »
If you use nentsel it will allow picking of an attribute rather than a block.
tombu
  • ByLayer=>Not0
« Reply #2 on: June 19, 2019, 07:25:09 AM »
You can also sub-select an attribute to edit it's properties with the Properties Palette by holding the Ctrl key down to sub-select it.  Double click on an attribute while holding down the Ctrl key to edit it in place.
Tom Beauford P.S.M.
alanjt
  • Standby for witty remark...
« Reply #3 on: June 19, 2019, 11:59:08 AM »
When the selection is returned from the double click, you can extract the selection point with ssnamex, then use nentselp to select select the attribute.
eg.
(nentselp (cadar (cdddar (ssnamex ss))))
The "ss" being the stored selection set, which would only work for a single object selection.
Dropbox
Grrr1337
« Reply #4 on: June 19, 2019, 12:19:34 PM »
Maybe a DoubleClick reactor will do?
  1. (defun C:testOn nil (DClickOnAttribute t)(princ))
  2. (defun C:testOff nil (DClickOnAttribute nil)(princ))
  3.
  4. (defun DClickOnAttribute ( flg )
  5.   (
  6.     (lambda ( rtrnm flg ) (vl-load-com)
  7.       (foreach rtr (cdar (vlr-reactors :VLR-Mouse-reactor)) (if (= rtrnm (vlr-data rtr)) (vlr-remove rtr)) )
  8.       (foreach rtr (cdar (vlr-reactors :VLR-Command-Reactor)) (if (= rtrnm (vlr-data rtr)) (vlr-remove rtr)) )
  9.       (if flg
  10.         (progn
  11.           (alert "\nDoubleClick On Attribute Reactor is ON")
  12.           (vlr-Mouse-Reactor rtrnm '((:VLR-BeginDoubleClick . Mouse:CB)))
  13.           (vlr-Command-Reactor rtrnm '((:VLR-commandWillStart . Cmd:CB)))
  14.         ); progn
  15.         (alert "\nDoubleClick On Attribute Reactor is OFF")
  16.       ); if
  17.
  18.       (princ)
  19.     ); lambda
  20.     "test" flg
  21.   )
  22. )
  23.
  24. ; CallBack functions -
  25. (defun Mouse:CB ( rtr args / o )
  26.   (and
  27.     (setq o (car (nentselp (car args))))
  28.     (setq o (vlax-ename->vla-object o))
  29.     (eq (vla-get-ObjectName o) "AcDbAttribute")
  30.     (alert (strcat "Attribute selected:" "\n" (vlax-get o 'TagString) "\n"(vlax-get o 'TextString)))
  31.   )
  32. )
  33.
  34. (defun Cmd:CB ( rtr args / wsh )
  35.   (if (member (strcase (car args)) '("EATTEDIT" "QUICKPROPERTIES" "RATRRED" "WLASCIWOSCI"))
  36.     (progn
  37.       (and
  38.         (setq wsh (vlax-get-or-create-object "WScript.Shell"))
  39.         (vl-catch-all-apply (function (lambda nil (vlax-invoke-method wsh 'SendKeys "{ESC}"))))
  40.       )
  41.       (vl-catch-all-apply 'vlax-release-object (list wsh))
  42.       t
  43.     )
  44.   ); and
  45. ); defun Cmd:CB
Somewhat related thread
(apply ''((a b c)(a b c))
vevo.bg
donnieworld
  • BricsCAD Fan
« Reply #5 on: June 19, 2019, 02:00:49 PM »
eg.
This is working  ... Thanks
Donald Broussard
Grrr1337
« Reply #6 on: June 19, 2019, 04:44:14 PM »
Alternative with grread:
  1. ; Prompting for a double-click on a object (with grread)
  2. (defun C:test ( / pb *error* s k v L pL e )
  3.
  4.   (setq pb (getvar 'pickbox))
  5.   (setvar 'pickbox (* 2.0 pb))
  6.
  7.   (defun *error* ( m )
  8.     (and pb (setvar 'pickbox pb))
  9.     (and m (princ m)) (princ)
  10.   ); defun *error*
  11.
  12.   (princ "\nDouble click on a object <exit>: ")
  13.   (while (not s)
  14.     (mapcar 'set '(k v) (grread))
  15.     (and (equal (list k v) '(2 13)) (setq s t))
  16.     (cond
  17.       ( (= 3 k) ; LMB
  18.         (setq L (cons (getvar 'cdate) L))
  19.         (setq pL (cons v pL))
  20.         (and
  21.           (>= (length L) 2)
  22.           (>= (length pL) 2)
  23.           (< (- (car L) (cadr L)) 1.0021e-06)
  24.           (equal (car pL) (cadr pL) 1e-3)
  25.           (progn
  26.             (setq L nil)
  27.             (setq pL nil)
  28.             (if (setq e (car (nentselp v)))
  29.               (progn
  30.                 (alert (cdr (assoc 0 (entget e))))
  31.                 (setq s t)
  32.               )
  33.               (princ "\nMissed!")
  34.             )
  35.
  36.           ); progn
  37.         ); and
  38.       ); LMB
  39.       ( (= 25 k) (setq s t) )
  40.     )
  41.   ); while
  42.   (*error* nil)
  43.   (princ)
  44. ); defun C:test
vevo.bg
BIGAL
« Reply #7 on: June 19, 2019, 09:48:54 PM »
Be careful lots of other commands use double click, in a layout dbl click to change space. Code not tested .
