Author Topic: UpdateScreen ...Proof of concept  (Read 4817 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« on: June 15, 2019, 11:09:30 PM »
Placeholder
Refer : https://forums.autodesk.com/t5/net/show-and-hide-layers-using-c-net/m-p/8818781#M62708
Video .MP4 Attached + Piccys
added kdub:
Source attached in Post Reply #4
« Last Edit: June 16, 2019, 04:44:01 AM by kdub »
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
  • SuperMod
Re: UpdateScreen ...Proof of concept
« Reply #1 on: June 15, 2019, 11:20:39 PM »
The aim was to demonstrate that Editor.UpdateScreen() Worked in a manner required by the OP
Commands Code
Code - C#: [Select]
  1. // (C) Copyright 2019 by kdub
  2. //
  3. using System;
  4. using System.Collections.Generic;
  5. using System.Linq;
  6. using System.Text;
  7. using Autodesk.AutoCAD.ApplicationServices;
  8. using Autodesk.AutoCAD.Colors;
  9. using Autodesk.AutoCAD.DatabaseServices;
  10. using Autodesk.AutoCAD.EditorInput;
  11. using Autodesk.AutoCAD.Geometry;
  12. using Autodesk.AutoCAD.Runtime;
  13.
  14. using Exception = System.Exception;
  15. using cadApp = Autodesk.AutoCAD.ApplicationServices.Application;
  16.
  17. [assembly: ExtensionApplication(typeof(TestDialog0615.Initialization))]
  18. [assembly: CommandClass(typeof(TestDialog0615.Commands))]
  19.
  20. namespace TestDialog0615
  21. {
  22.     public class Commands
  23.     {
  24.         [CommandMethod("TEST")]
  25.         public void Test()
  26.         {
  27.             SetupForTest();
  28.
  29.             SetupDialog();
  30.         }
  31.
  32.         private static void SetupDialog()
  33.         {
  34.             using (var dialog = new ModalDialog())
  35.             {
  36.                 var showResult = cadApp.ShowModalDialog(dialog);
  37.                 if (showResult == System.Windows.Forms.DialogResult.OK)
  38.                 {
  39.                     cadApp.ShowAlertDialog("All Good");
  40.                 }
  41.             }
  42.         }
  43.
  44.
  45.         private static void SetupForTest()
  46.         {
  47.             dynamic layerTable = Active.Database.LayerTableId;
  48.             string layerName = "RedStuff";
  49.             if (!layerTable.Has(layerName))
  50.             {
  51.                 Active.Database.CreateLayer(layerName, Color.FromColorIndex(ColorMethod.ByAci, 1));
  52.             }
  53.
  54.             layerName = "GreenStuff";
  55.             if (!layerTable.Has(layerName))
  56.             {
  57.                 Active.Database.CreateLayer(layerName, Color.FromColorIndex(ColorMethod.ByAci, 3));
  58.             }
  59.
  60.             layerName = "BlueStuff";
  61.             if (!layerTable.Has(layerName))
  62.             {
  63.                 Active.Database.CreateLayer(layerName, Color.FromColorIndex(ColorMethod.ByAci, 5));
  64.             }
  65.
  66.             CreateSomeCquircles();
  67.         }
  68.         private static void CreateSomeCquircles()
  69.         {
  70.             Active.Database.UsingModelSpace(
  71.                 (tr, ms) =>
  72.                 {
  73.                     var rnd = new Random(DateTime.Now.Second);
  74.                     string layerName;
  75.                     for (int i = 0; i < 60; i++)
  76.                     {
  77.                         var x = rnd.NextDouble() * 125;
  78.                         var y = rnd.NextDouble() * 100;
  79.                         var r = rnd.NextDouble() * 25;
  80.
  81.                         if (i > 40) layerName = "RedStuff";
  82.                         else if (i > 20) layerName = "GreenStuff";
  83.                         else layerName = "BlueStuff";
  84.
  85.                         ms.Create<Circle>(
  86.                             tr, circle =>
  87.                             {
  88.                                 circle.Center = new Point3d(x, y, 0.0);
  89.                                 circle.Radius = r;
  90.                                 circle.Layer = layerName;
  91.                             });
  92.                     }
  93.                 });
  94.         }
  95.     }
  96.
  97.
  98.     //=====================================================
  99.
  100.     public class Initialization : IExtensionApplication
  101.     {
  102.         public void Initialize()
  103.         {
  104.             cadApp.Idle += OnIdle;
  105.         }
  106.
  107.         private void OnIdle(object sender, EventArgs e)
  108.         {
  109.             if (Active.Document != null)
  110.             {
  111.                 cadApp.Idle -= OnIdle;
  112.                 Active.WriteMessage("\nTestDialog0615 loaded.\n");
  113.                 Active.WriteMessage("Enter \"TEST\" at the CommandLine.\n");
  114.             }
  115.         }
  116.
  117.         public void Terminate()
  118.         { }
  119.     }
  120. }
  121.
  122.
Dialog Code
Code - C#: [Select]
  1. using System;
  2. using System.Windows.Forms;
  3. using Autodesk.AutoCAD.DatabaseServices;
  4. using cadApp = Autodesk.AutoCAD.ApplicationServices.Application;
  5.
  6.
  7. namespace TestDialog0615
  8. {
  9.     public partial class ModalDialog : Form
  10.     {
  11.         public ModalDialog()
  12.         {
  13.             InitializeComponent();
  14.         }
  15.
  16.         private void ModalDialog_Load(object sender, EventArgs e)
  17.         {
  18.
  19.         }
  20.
  21.
  22.         private void CbRed_CheckedChanged(object sender, EventArgs e)
  23.         {
  24.             if (cbRed.Checked)
  25.             {
  26.                 TurnLayerOnOff("RedStuff", true);
  27.                 textBox.Text = "Red Checked";
  28.                 Active.Editor.UpdateScreen();
  29.             }
  30.             else
  31.             {
  32.                 TurnLayerOnOff("RedStuff", false);
  33.                 textBox.Text = "Red Unchecked";
  34.                 Active.Editor.UpdateScreen();
  35.             }
  36.         }
  37.
  38.         private void CbGreen_CheckedChanged(object sender, EventArgs e)
  39.         {
  40.             if (cbGreen.Checked)
  41.             {
  42.                 TurnLayerOnOff("GreenStuff", true);
  43.                 textBox.Text = "Green Checked";
  44.                 Active.Editor.UpdateScreen();
  45.             }
  46.             else
  47.             {
  48.                 TurnLayerOnOff("GreenStuff", false);
  49.                 textBox.Text = "Green Unchecked";
  50.                 Active.Editor.UpdateScreen();
  51.             }
  52.         }
  53.
  54.         private void CbBlue_CheckedChanged(object sender, EventArgs e)
  55.         {
  56.             if (cbBlue.Checked)
  57.             {
  58.                 TurnLayerOnOff("BlueStuff", true);
  59.                 textBox.Text = "Blue Checked";
  60.                 Active.Editor.UpdateScreen();
  61.             }
  62.             else
  63.             {
  64.                 TurnLayerOnOff("BlueStuff", false);
  65.                 textBox.Text = "Blue Unchecked";
  66.                 Active.Editor.UpdateScreen();
  67.             }
  68.         }
  69.
  70.         private void ButtonZoom_Click(object sender, EventArgs e)
  71.         {
  72.             //Call the COM library
  73.             dynamic acadApp = cadApp.AcadApplication;
  74.             acadApp.ZoomExtents();
  75.             acadApp.ZoomScaled(0.75, 1);
  76.         }
  77.
  78.         // should not be in the Dialog Stuff; move to control file :kdub
  79.         // and change to use delegates
  80.         private  void TurnLayerOnOff(
  81.             string layerName, bool isOffp)
  82.         {
  83.             using (var tr = Active.Database.TransactionManager.StartTransaction())
  84.             {
  85.                 var layerTable = tr.GetObject(
  86.                     Active.Database.LayerTableId, OpenMode.ForRead) as LayerTable;
  87.                 if (layerTable != null)
  88.                 {
  89.                     if (layerTable.Has(layerName))
  90.                     {
  91.                         var layerTableRecord = tr.GetObject(
  92.                             layerTable[layerName], OpenMode.ForWrite) as LayerTableRecord;
  93.                         if (layerTableRecord != null)
  94.                         {
  95.                             layerTableRecord.IsOff = isOffp;
  96.                         }
  97.                     }
  98.                 }
  99.                 tr.Commit();
  100.             }
  101.         }
  102.     }
  103. }
  104.
  105.
gile
  • Marseille, France
« Reply #2 on: June 16, 2019, 04:04:13 AM »
Hi Kerry,
The code you provided uses static properties of an Active class and some Extension methods you do not show.
I think a 'proof of concept' should be testable by anyone 'as is' (but may be I'm wrong).
« Last Edit: June 16, 2019, 04:21:58 AM by gile »
kdub_nz
  • SuperMod
« Reply #3 on: June 16, 2019, 04:18:02 AM »
Hi Gilles
The main issue was the Editor.UpdateScreen() working when there was no user access to more than the dialog.
More than anything I wanted to confirm my understanding.
I'll package the Solution and post it.
Regards
kdub_nz
  • SuperMod
« Reply #4 on: June 16, 2019, 04:24:16 AM »
Attached are the source files and solution .
I build with VS 2019 for ACAD 2020 on WIN 10 64bit
ObjectARX SDK is D:\ObjectARX 2020
Enjoy
gile
  • Marseille, France
« Reply #5 on: June 16, 2019, 04:26:51 AM »
Hi Gilles
Yes i understand, it was just a remark before someone come with: "It does not work !".
kdub_nz
  • SuperMod
« Reply #6 on: June 16, 2019, 04:28:38 AM »
Hi Gilles
Yep !
Atook
  • AKA Tim
« Reply #7 on: June 17, 2019, 01:45:29 AM »
Do you find that UpdateScreen() is faster than Regen()?
Reading this, it seems like Regen() has more calculations in it than UpdateScreen().
I've only used Regen(), this is the first I'd heard of UpdateScreen().
MickD
« Reply #8 on: June 17, 2019, 02:16:55 AM »
Just shooting from the hip here but Regen having more calculations 'sounds' about right, it's regenerating the whole image from the database whereas UpdateScreen is probably just checking some flags associated with the last buffered image data, in this case 'Layer' names and only draws what is needed.
that is, it's only drawing what it already knows but with a different 'state'.
- John Carmack
- J.R.R. Tolkien
kdub_nz
  • SuperMod
« Reply #9 on: June 17, 2019, 02:23:59 AM »
Hi Tim,
I was happy to use UpdateScreen() because all that was being done was turning layers on/off ... nothing that required a recalculation of object locations.
If there was changes to geometry and entity addition/removal Regen() may be better.
I've never done an analysis on the relative uses of either though.
In this case the requirements were simply to visually interactively confirm the resulting display.
Thanks for the comment.
Regards,
added: Ooops, Mick stole my thunder :)
« Last Edit: June 17, 2019, 02:29:05 AM by kdub »
MickD
« Reply #10 on: June 17, 2019, 02:34:32 AM »
Not at all, I think both comments compliment each other :)
- John Carmack
- J.R.R. Tolkien
kdub_nz
  • SuperMod
« Reply #11 on: June 17, 2019, 02:43:34 AM »
Yes, I'd anticipate a difference. Perhaps someone with some spare time will run a test and let us know   :wink:
I'll be interested to hear from the query originator if this solution suits their process.
kdub_nz
  • SuperMod
« Reply #12 on: June 17, 2019, 03:03:02 AM »
In response to a PM question.:
The Extension class, the Common class and the Linq class are derived from lectures given by Scott McFarlane at Autodesk University.
https://www.autodesk.com/autodesk-university/au-online?query=Scott+McFarlane
2012   Programming AutoCAD® with C#: Best Practices
2014   Sharpen Your C# Code for AutoCAD
2015   Being a Remarkable C# .NET AutoCAD Developer
It's a Wonderland, but be prepared go down the rabbit hole ...
They make no real variation in functionality for this exercise, but they are pretty to look at.
