Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Edit path type for images via lisp
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Edit path type for images via lisp (Read 2108 times)
densan
Mosquito
on:
June 11, 2019, 08:32:22 PM »
Hello everyone,
I am trying to find a function to set the path of attached images to NONE. I am familiar with the reference manager tool but I am looking for automation via lisp, as it will be part of a major cleanup process in 1000's of drawings.
Found the following code but it's only removing the path for one image even though the drawing contains multiple images.
I only know basic lisp concepts but I don't understand why the code it's not looping.
Thank you for any help you can offer,
Code - Auto/Visual Lisp:
[Select]
;;;Jeff Mishler, Dec 2, 2004
;;;Removes path from images
defun
repath_images
ss i img iname
setq
ss
ssget
"X"
0
"IMAGE"
setq
i
1
while
setq
i
1+
i
sslength
ss
setq
vlax
ename
vla-object
ssname
ss i
Iname
vla-get-imagefile
while
vl-string-search
Iname
setq
Iname
substr
Iname
2
vla-put-imagefile
img Iname
Logged
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
class keyThumper<T>:ILazy<T>
Re: Edit path type for images via lisp
Reply #1 on:
June 11, 2019, 09:55:19 PM »
Welcome to the swamp.
Jeff's routine works for me.
This is from BricsCAD V19
I can't see anything in the code that would fail and cause your issue in AutoCAD.
Logged
Called Kerry in my other life
I live at UTC + 13.00
densan
Mosquito
Reply #2 on:
June 12, 2019, 11:11:09 AM »
Thank you Kdub, I moved the lisp to a trusted location folder and the weird behavior disappeared.
May I ask, what would be the correct way to add an
IF
statement (line 5 in revised code) or a way to process the function if images exist in the drawing.
[Select]
defun
c:repath_images
ss i img iname
setq
ss
ssget
"X"
0
"IMAGE"
;; (if (/= ss nil) then? <- where to start the IF
setq
i
1
while
setq
i
1+
i
sslength
ss
setq
vlax
ename
vla-object
ssname
ss i
Iname
vla-get-imagefile
while
vl-string-search
Iname
setq
Iname
substr
Iname
2
vla-put-imagefile
img Iname
Logged
ribarm
Gator
Marko Ribar, architect
WWW
Reply #3 on:
June 12, 2019, 11:27:51 AM »
[Select]
if
setq
ss
ssget
"X"
0
"IMAGE"
progn
Just edit line 4 and 5 and add closing ) at the end of (progn ...
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
Seagull
London, England
WWW
Reply #4 on:
June 12, 2019, 01:02:08 PM »
Here's an alternative that will also target unreferenced image xrefs -
[Select]
defun
c:repath_images
d i x
if
setq
d
cdr
assoc
1
dictsearch
namedobjdict
"acad_image_dict"
while
setq
i
dictnext
d
not
i
if
wcmatch
cdr
setq
x
assoc
1
i
entmod
subst
cons
1
apply
strcat
cdr
fnsplitl
cdr
x
x i
princ
Logged
Lee Mac Programming
Twitter
Exchange App Store
densan
Mosquito
Reply #5 on:
June 12, 2019, 03:53:06 PM »
I want to say thank very much to everyone in this post, I appreciate the help and I look forward to continue learning from this great forum.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
