Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Purge script not working
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Purge script not working (Read 2362 times)
notredave
Newt
on:
June 04, 2019, 12:29:45 PM »
All,
Good afternoon. Can someone please tell me why this script isn't working? I am using Lee Mac's script writer. And if someone doesn't mind adding purging regapps, I would appreciate it.
_.open *file* -purge A N _.close y
Thank you much,
David
Logged
57gmc
Bull Frog
Re: Purge script not working
Reply #1 on:
June 04, 2019, 12:55:54 PM »
What makes you think its not working? Can you purge the file normally without the script?
Logged
Needs a day job
Reply #2 on:
June 04, 2019, 01:02:51 PM »
Try something like this .. you're forgetting the "*" in the prompts. This will do regapps as well.
Code - Auto/Visual Lisp:
[Select]
defun
_purge
nil
setvar
'cmdecho
0
foreach
x '
"_A"
"_R"
command
".-purge"
x
"_N"
setvar
'cmdecho
1
princ
_purge
Logged
notredave
Newt
Reply #3 on:
June 04, 2019, 01:59:31 PM »
ronjonp,
Thank you for this but how will this work in a script file? I am using Lee Mac's script writer.
Logged
Needs a day job
Reply #4 on:
June 04, 2019, 02:28:11 PM »
Make sure the sub is loaded then: _.open *file* (_purge) _.close y
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
