Author Topic: Map .Net / Importer  (Read 1815 times)
nobody
  • .net stuff
Map .Net / Importer
« on: June 02, 2019, 07:35:53 AM »
Possible to run the importer with different shape files more than once in a session?  Trying to import shape files from 2 different paths. It works fine when I run them in a single operation, but if I try to run them separately it seems Map hates me.
Thanks!
« Last Edit: June 02, 2019, 08:06:06 AM by quaziconscience »
nobody
  • .net stuff
Re: Map .Net / Importer
« Reply #1 on: June 02, 2019, 06:42:36 PM »
Thanks!
Nevermind. Appears I can declare/run the import engine multiple times.
Appears it was just having trouble with the table naming when I separated the activities.  Simple test for name fixed it <  :idiot2:
