Author Topic: Double Tag in EVERY DWG  (Read 4488 times)
Mystogan
  • Mosquito
« on: May 31, 2019, 05:27:12 AM »
Hi to all,
Would like to know if there's a way that LISP can give a summary of double tag(I'm referring to text values, attribute value, Mtext) in one dwg file then proceed to another dwg file and give another summary list.
It would better about the execution it will produce excel file.
Thank you in advance.
kpblc
Re: Double Tag in EVERY DWG
« Reply #1 on: May 31, 2019, 05:38:11 AM »
Sorry for my English.
roy_043
  • BricsCAD 18
« Reply #2 on: May 31, 2019, 06:33:28 AM »
What is a 'double tag'?
« Reply #3 on: May 31, 2019, 03:05:38 PM »
I'm guessing multiple annotation objects with the same text content.
Mystogan
  • Mosquito
« Reply #4 on: June 02, 2019, 11:31:20 PM »
Yes, that's correct...
Hope you can help me
BIGAL
  • 40 + years of using Autocad
« Reply #5 on: June 09, 2019, 06:13:10 AM »
If you do a ssget with *text that handles mtext and text then make a list of the text and the entity name then do a sort. next step is compare two items sequentially in the list if they match get further details and write a csv file etc. this stores the handle id which can be used to retrieve object data. use (handent "handle id") to
Here is a start
(setq ss (ssget "x" (list (cons 0 "*text"))))
(setq lst '())
(repeat (setq x (sslength ss))
(setq ent (entget (ssname ss (setq x (- x 1)))))
(setq lst (cons (list (cdr (assoc 1 ent)) (cdr (assoc 5 ent))) lst))
(setq lst (vl-sort lst
             (function (lambda (e1 e2)
                         (< (car e1) (car e2)))))
(setq x 0)
(setq t1 (nth 0 (nth 0 lst)))
(repeat (- (length lst) 1)
(setq t2 (nth 0 (nth (+ x 1) lst)))
(if (= t1 t2)
(alert (strcat "match found \n \n do write csv here\n \n" t1))
(setq t1 t2)
(setq t1 t2)
(setq x (+ x 1))
(setq ent (entget (handent "handle id"))) ; to retrieve object data
« Last Edit: June 09, 2019, 06:28:33 AM by BIGAL »
Mystogan
  • Mosquito
« Reply #6 on: June 12, 2019, 10:42:50 PM »
Here is a start
(setq lst '())
(setq x 0)
(if (= t1 t2)
(setq t1 t2)
(setq t1 t2)
(setq x (+ x 1))
Hi BIGAL,
Thank you for the initiative of the code. Unfortunately I have no idea on where to put and completely rewrite your code that can give me a command/execution key
roy_043
  • BricsCAD 18
« Reply #7 on: June 13, 2019, 09:53:07 AM »
IMO the definition of a 'double tag' is still unclear.
Example:
There are 10 columns in a plan that all have an mtext annotation identifying their dimensions as "300x300".
Should 9 mtext objects be removed?
« Reply #8 on: June 13, 2019, 12:42:31 PM »
And if so, which 9?
Mystogan
  • Mosquito
« Reply #9 on: June 13, 2019, 10:07:02 PM »
Example:
Hi sir roy_043
To make a more clear perspective of the intent is like. In using command Find in autocad it will give you list of exact word/letter that you want to look for and you notice there is two or more same work/letter. That's what I want that list of word.
In other command of autocad known as data extraction here you can have a list of block value/mtext/text etc.,This is what I'm looking a summary of value. The command key should be extract only the block value/mtext/text. With this command you don't need check/uncheck other function in data extraction.
It is posibble?
roy_043
  • BricsCAD 18
« Reply #10 on: June 14, 2019, 04:25:21 AM »
@Mystogan:
Comparing what you want to _Find and _DataExtraction is not very clear as these commands are quite different.
BIGAL
« Reply #11 on: June 19, 2019, 02:16:35 AM »
So you want how many "300x300" occurs but done for every word combo ?
Mystogan
  • Mosquito
« Reply #12 on: June 20, 2019, 11:33:55 PM »
yes
« Reply #13 on: June 21, 2019, 08:00:41 AM »
Here's an old program which may help: Text Counter
Mystogan
  • Mosquito
« Reply #14 on: June 27, 2019, 03:59:36 AM »
This is what am looking for Thank you very much sir Lee Mac
