Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
AutoLISP (Vanilla / Visual)
Topic:
fill_image in OpenDCL
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: fill_image in OpenDCL (Read 2334 times)
mailmaverick
Bull Frog
on:
May 25, 2019, 12:07:42 PM »
Hi
Can we use fill_image in OpenDCL PixtureBox or any other OpenDCL Control ?
If yes, then please let me know how. I have tried passing the OpenDCL Control name "c:Form/Main/PictureBox1" to fill_image but couldn't generate the image.
Thanks.
Logged
roy_043
Water Moccasin
BricsCAD 18
Re: fill_image in OpenDCL
Reply #1 on:
May 25, 2019, 12:33:57 PM »
The fill_image function is not an ODCL function. Look at dcl-SlideView-FillImage instead?
Logged
mailmaverick
Bull Frog
Reply #2 on:
May 25, 2019, 12:57:34 PM »
Thanks for reply.
I have particular lines stored as coordinates which I want to draw in either dcl-PictureBox or dcl-SlideView.
I've tried many syntaxes such as :-
(dcl-PictureBox-DrawLine "C:Form/Main/PictureBox1" (list (list 0 0) (list 10 10) 1))
(dcl-PictureBox-DrawLine "C:Form/Main/PictureBox1" (list (list 0 0 10 10 1))
but every time I get following error :-
Please help where the syntax is wrong ?
Logged
roy_043
Water Moccasin
BricsCAD 18
Reply #3 on:
May 25, 2019, 04:07:05 PM »
Instead of guessing the syntax and the required type of the arguments why nor Read The Manual! Check the Help or the Control Browser. There is even a sample file (Methods.lsp).
Logged
Peter2
Swamp Rat
Reply #4 on:
May 27, 2019, 02:27:33 AM »
The help says:
Code - Auto/Visual Lisp:
[Select]
dcl
PictureBox
DrawLine
CONTROL
List
of Lists as
StartX
as Long
StartY
as Long
EndX
as Long
EndY
as Long
Color
as Color
So it seem that you have one list per line and you can create many lines.
And are you sure that you call the form in a right way? "C:form" looks a little bit strange for me ..
Logged
Peter
BricsCAD V23
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
class keyThumper<T>:ILazy<T>
Reply #5 on:
May 27, 2019, 06:24:00 AM »
Try this :
(see attachments)
[Select]
;|*Main Entry Point*|;
defun
c:testpb01
;; Ensure OpenDCL Runtime is (quietly) loaded
setq
cmdecho
getvar
"CMDECHO"
setvar
"CMDECHO"
0
command
"_OPENDCL"
setvar
"CMDECHO"
cmdecho
;; Load the project
if
dcl
Project
Load
FindFile
"TestPB.odcl"
T
progn
setq
Result
dcl
Form
Show TestPB
Form1
;; (if (= Result 1) (DoSomething))
princ
;|*OpenDCL Event Handlers*|;
defun
c:TestPB
Form1
doit#OnClicked
dcl
PictureBox
DrawLine
TestPB
Form1
PictureBox1
10
10
100
50
42
10
50
100
50
2
dcl
PictureBox
DrawLine
TestPB
Form1
PictureBox1
10
10
230
10
248
10
20
230
20
249
10
30
230
30
250
10
40
230
40
251
10
50
230
50
252
10
60
230
60
253
10
70
230
70
254
10
80
230
80
255
added:
Just noticed the code referred to by roy ... So added the data from that too.
Last Edit: May 27, 2019, 06:45:56 AM by kdub
Logged
Called Kerry in my other life
I live at UTC + 13.00
mailmaverick
Bull Frog
Reply #6 on:
May 28, 2019, 12:23:28 AM »
Thanks KDUB . Perfectly Works !!!!
Logged
Print
Pages: [
1
Go Up
« previous
next »
Code Red
Topic:
