Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Revision cloud "flattening"
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Revision cloud "flattening" (Read 1515 times)
notredave
Newt
on:
May 23, 2019, 03:09:47 PM »
All,
Good afternoon. I'm in the process of doing a lot of scoping on ~ 150 drawings and client comes back with comments which affects what needs to be in the scope or not. I use a pline to draw around items that need to be scoped, then use Annotate --> Markup --> Revision Cloud and click on object (pline). My question is, does anyone know of a lisp routine that would turn my scoping arcs back to straight plines so I can make my corrections and scope it back without having to draw all my plines again?
Thank you,
David
Also found here:
https://www.cadtutor.net/forum/topic/67781-revision-cloud-flattening/
Logged
tombu
Bull Frog
ByLayer=>Not0
Re: Revision cloud "flattening"
Reply #1 on:
May 23, 2019, 04:03:59 PM »
If you drew a polyline and used the object selection option of Revision Cloud then it should still show as a polyline in Properties. You can either Pedit and Decurve or just edit it as is.
Logged
Tom Beauford P.S.M.
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
