Author Topic: How to extend or cut?  (Read 4050 times)
myloveflyer
« on: May 22, 2019, 03:44:25 AM »
How to extend or cut a straight line by changing the diameter of the circle?See the DWG in the attachment for details.
Never give up !
Re: How to extend or cut?
« Reply #1 on: May 22, 2019, 10:58:26 AM »
Better yet use a block with a mask and draw your lines to the insertion points  :wink:
myloveflyer
« Reply #2 on: May 23, 2019, 09:26:16 PM »
The drawings are from other software, because the diameter of the circle is fixed at the beginning, and the later labor needs to modify the diameter of the circle to make the line extend and cut.
Can you help me write this program to complete the straight line extension and cutting?
Never give up !
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #3 on: May 23, 2019, 11:49:45 PM »
First thought
Select all by window filtered for lines and circles.
Isolate a circle in selection set
Determine current diameter
Prompt for new diameter
Calculate amount to reduce each end of each line ( half difference in circle size )
Iterate thtough selection set
If Circle, change diameter
If Line, calculate new start and end points based on calculated offset, move endpoints.
   Moving keeps any additional data associated with entity.
Go for a beer.
Called Kerry in my other life
I live at UTC + 13.00
BIGAL
  • 40 + years of using Autocad
« Reply #4 on: May 24, 2019, 08:24:01 PM »
Try this
; defun trim inside circles
; By Alan H May 2019 AlanH Consulting
; www.alanh.com.au
(defun aH:trimcircles (/ ss ang rad oldsnap oldaunits obj lay)
  (setq oldsnap (getvar "osmode"))
  (setq oldaunits (getvar 'aunits))
  (setq lay (cdr (assoc 8 (entget (car (entsel "Pick circle"))))))
  (setq ss (ssget (list (cons 0 "Circle") (cons 8 lay))))
  (setvar 'osmode 0)
  (setvar 'aunits 3)
  (repeat (setq x (sslength ss))
    (setq obj (entget (ssname ss (setq x (- x 1)))))
    (setq rad (cdr (assoc 40 obj)))
    (setq cenpt (list (nth 1 (assoc 10 obj)) (nth 2 (assoc 10 obj))))
    (setq ent (cdr (assoc -1 obj)))
    (setq rad (- rad 3))
    (setq lst '())
    (setq ang 0.0)
    (repeat 10
      (setq lst (cons (polar cenpt ang rad) lst))
      (setq ang (+ ang 0.62831853))
    (command "trim" ent "" "fence")
    (while (= (getvar "cmdactive") 1)
      (repeat (setq y (length lst))
        (command (nth (setq y (- y 1)) lst))
      (command "" "")
  (setvar 'osmode oldsnap)
  (setvar 'aunits oldaunits)
(aH:trimcircles)
(defun c:trci () (aH:trimcircles))
roy_043
  • BricsCAD 18
« Reply #5 on: May 25, 2019, 05:56:07 AM »
  1. (defun KGA_Conv_Pickset_To_ObjectList (ss / i ret)
  2.   (if ss
  3.     (repeat (setq i (sslength ss))
  4.       (setq ret (cons (vlax-ename->vla-object (ssname ss (setq i (1- i)))) ret))
  5.     )
  6.   )
  7. )
  8.
  9. (defun c:Test ( / cen cirLst doc linLst radNew radOld ss)
  10.   (if
  11.     (and
  12.       (setq ss (ssget '((0 . "LINE,CIRCLE"))))
  13.       (setq radNew (getreal "\nNew radius: "))
  14.     )
  15.     (progn
  16.       (foreach obj (KGA_Conv_Pickset_To_ObjectList ss)
  17.         (if (= "AcDbLine" (vla-get-objectname obj))
  18.           (setq linLst
  19.             (vl-list*
  20.               (list (vlax-get obj 'startpoint) T obj)
  21.               (list (vlax-get obj 'endpoint) nil obj)
  22.               linLst
  23.             )
  24.           )
  25.           (setq cirLst (cons obj cirLst))
  26.         )
  27.       )
  28.       (foreach cir cirLst
  29.         (setq cen (vlax-get cir 'center))
  30.         (setq radOld (vla-get-radius cir))
  31.         (vla-put-radius cir radNew)
  32.         (foreach sub linLst
  33.           (if (equal radOld (distance cen (car sub)) 1e-8)
  34.             (progn
  35.               (vlax-put
  36.                 (caddr sub)
  37.                 (if (cadr sub) 'startpoint 'endpoint)
  38.                 (vlax-curve-getclosestpointto cir (car sub))
  39.               )
  40.               (setq linLst (vl-remove sub linLst))
  41.             )
  42.           )
  43.         )
  44.       )
  45.     )
  46.   )
  47.   (princ)
  48. )
« Last Edit: May 25, 2019, 06:00:31 AM by roy_043 »
« Reply #6 on: May 26, 2019, 12:36:29 AM »
  2.   (if ss
  5.     )
  6.   )
  7. )
  8.
  10.   (if
  11.     (and
  14.     )
  15.     (progn
  18.           (setq linLst
  19.             (vl-list*
  22.               linLst
  23.             )
  24.           )
  26.         )
  27.       )
  34.             (progn
  35.               (vlax-put
  36.                 (caddr sub)
  39.               )
  41.             )
  42.           )
  43.         )
  44.       )
  45.     )
  46.   )
  47.   (princ)
  48. )
Nice  8-)
myloveflyer
« Reply #7 on: May 26, 2019, 09:07:25 PM »
  2.   (if ss
  5.     )
  6.   )
  7. )
  8.
  10.   (if
  11.     (and
  14.     )
  15.     (progn
  18.           (setq linLst
  19.             (vl-list*
  22.               linLst
  23.             )
  24.           )
  26.         )
  27.       )
  34.             (progn
  35.               (vlax-put
  36.                 (caddr sub)
  39.               )
  41.             )
  42.           )
  43.         )
  44.       )
  45.     )
  46.   )
  47.   (princ)
  48. )
Thanks,roy_043!
But some CAD is a streamlined version, and a VL-function needs to add a line of code when it runs.
  (if ss
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (vla-endundomark doc)
  (vla-startundomark doc)
    (and
          (setq linLst
            (vl-list*
              linLst
      (foreach cir cirLst
        (foreach sub linLst
              (vlax-put
                (caddr sub)
Never give up !
kdub_nz
  • SuperMod
« Reply #8 on: May 26, 2019, 10:07:35 PM »
Nice solution Roy
kdub_nz
  • SuperMod
« Reply #9 on: May 26, 2019, 10:19:49 PM »
That is really nit-picking. Most people who run customisation have the function call in one of theit start-up files.
myloveflyer
« Reply #10 on: May 27, 2019, 04:37:31 AM »
Thanks,kdub!Thank you for reminding me, I will pay attention to this when I write the program in the future!
Never give up !
BIGAL
« Reply #11 on: May 27, 2019, 11:10:01 PM »
Put your (vl-load-com) in your start up lisp then its always loaded.
