Author Topic: Cannot create ObjectDBX  (Read 1661 times)
cuda
  • Mosquito
« on: May 22, 2019, 03:27:13 AM »
Hello Guys,
I have a problem when running this code:
  1. (defun c:Example_CopyObjects()
  2.     ;; This example creates a Circle object and uses the CopyObjects
  3.     ;; method to make a copy of the new Circle.
  4.     (setq acadObj (vlax-get-acad-object))
  5.     (setq doc (vla-get-ActiveDocument acadObj))
  6.
  7.     ;; Load the ObjectDBX library
  8.     (if (= acLibImport nil)
  9.                (progn
  10.                    (vlax-import-type-library :tlb-filename "C:\\Program Files\\Common Files\\Autodesk Shared\\axdb20enu.tlb"
  11.                                              :methods-prefix "acdbm-"
  12.                                              :properties-prefix "acdbp-"
  13.                                              :constants-prefix "acdbc-"
  14.                    )
  15.             (setq acLibImport T)
  16.         )
  17.     )
  18.
  19.     ;; Create a reference to the ObjectDBX object
  20.     (setq acdbObj (vlax-create-object "ObjectDBX.AxDbDocument.20"))
  21. )
  22.
This piece of code is part of an example of "CopyObjects" method from ACAD2016 help file.
My problem is that the last line returns nil which isn't supposed to be. My AutoCAD2016 runs on windows10.  I tried this code on another win7 machine with the same version ACAD and it's OK. Could anybody please help me out?
roy_043
  • BricsCAD 18
Re: Cannot create ObjectDBX
« Reply #1 on: May 22, 2019, 03:33:54 AM »
Within little over 30 minutes you have posted the same problem 10 times. Please stop reposting and be a little patient!
myloveflyer
« Reply #2 on: May 22, 2019, 03:56:59 AM »
Hey, friend, it’s best to delete your same post.
Never give up !
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #3 on: May 22, 2019, 05:59:11 AM »
What does this return at the command line ( or in the VLIDE )
  1. (findfile "C:\\Program Files\\Common Files\\Autodesk Shared\\axdb20enu.tlb")
Called Kerry in my other life
I live at UTC + 13.00
