Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Cannot create ObjectDBX
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Cannot create ObjectDBX (Read 1672 times)
cuda
Mosquito
on:
May 22, 2019, 03:27:13 AM »
Hello Guys,
I have a problem when running this code:
Code - Auto/Visual Lisp:
[Select]
vl-load-com
defun
c:Example_CopyObjects
;; This example creates a Circle object and uses the CopyObjects
;; method to make a copy of the new Circle.
setq
acadObj
vlax-get-acad-object
setq
doc
vla-get-ActiveDocument
acadObj
;; Load the ObjectDBX library
if
acLibImport
nil
progn
vlax-import-type-library
:tlb-filename
"C:
Program Files
Common Files
Autodesk Shared
axdb20enu.tlb"
:methods-prefix
"acdbm-"
:properties-prefix
"acdbp-"
:constants-prefix
"acdbc-"
setq
acLibImport T
;; Create a reference to the ObjectDBX object
setq
acdbObj
vlax-create-object
"ObjectDBX.AxDbDocument.20"
This piece of code is part of an example of "CopyObjects" method from ACAD2016 help file.
My problem is that the last line returns nil which isn't supposed to be. My AutoCAD2016 runs on windows10. I tried this code on another win7 machine with the same version ACAD and it's OK. Could anybody please help me out?
Logged
roy_043
Water Moccasin
BricsCAD 18
Re: Cannot create ObjectDBX
Reply #1 on:
May 22, 2019, 03:33:54 AM »
Within little over 30 minutes you have posted the same problem 10 times. Please stop reposting and be a little patient!
Logged
myloveflyer
Newt
Reply #2 on:
May 22, 2019, 03:56:59 AM »
Hey, friend, it’s best to delete your same post.
Logged
Never give up !
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
class keyThumper<T>:ILazy<T>
Reply #3 on:
May 22, 2019, 05:59:11 AM »
What does this return at the command line ( or in the VLIDE )
[Select]
findfile
"C:
Program Files
Common Files
Autodesk Shared
axdb20enu.tlb"
Logged
Called Kerry in my other life
I live at UTC + 13.00
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
