Author Topic: Fatal error on very simple DWG  (Read 7865 times)
Marc'Antonio Alessi
  • Marco
« on: May 20, 2019, 04:25:54 PM »
Another very strange fatal error, symptoms:
AutoCAD2020> fatal error on copy/paste one block
BricsCAD V19> fatal error on move by grips
older versions OK  :gum:
see DWG.
Re: Fatal error on very simple DWG
« Reply #1 on: May 21, 2019, 10:35:10 AM »
No crashing here...
« Reply #3 on: May 21, 2019, 12:04:05 PM »
I have AutoCAD 2020 and no crashing on copy paste. First thing I'd do would be open the DWG with recover and see if that fixes the issue.
Marc'Antonio Alessi
  • Marco
« Reply #4 on: May 21, 2019, 01:01:23 PM »
Thanks for test, maybe I send the wrong file… try before recover.
Grazie.  :-)
« Reply #5 on: May 21, 2019, 01:51:55 PM »
Still no errors here.
ChrisCarlson
« Reply #6 on: May 21, 2019, 02:31:45 PM »
Unload all of your routines, it might be a reactor failing out.
« Reply #7 on: May 21, 2019, 03:08:02 PM »
What happens with the attached Marc?
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
Matthew H
« Reply #8 on: May 21, 2019, 03:53:30 PM »
Marc'Antonio Alessi's & MP's CAD file both Crash BricsCAD when touching the grip.
BricsCAD Ultimate Beta V19.201 (x64) Revison 60248 Beta
Marc'Antonio Alessi
  • Marco
« Reply #9 on: May 21, 2019, 03:56:18 PM »
Thanks Michael for test: BricsCAD V19 / AutoCAD 2020 same error  :-(
Marc'Antonio Alessi
  • Marco
« Reply #10 on: May 21, 2019, 04:01:01 PM »
I'm using a "Vanilla" profile in V19/A2020 ...I think that these are dynamic blocks created with AutoCAD and then imported into BricsCAD V14 (unfortunately I have a client that still uses this version)...
Marc'Antonio Alessi
  • Marco
« Reply #11 on: May 21, 2019, 04:08:34 PM »
Thanks Matthew, I have V19.2.07 rev.61634
« Reply #12 on: May 21, 2019, 04:10:32 PM »
Thanks for testing.
Started with lite abuse.
Next level abuse attached.
Please try; thanks.
« Reply #13 on: May 21, 2019, 04:13:34 PM »
Could this be part of it?
Non Autodesk DWG.  This DWG file was saved by a software application that was not developed or licensed by Autodesk.  Autodesk cannot guarantee the application compatibility or integrity of this file.
Marc'Antonio Alessi
  • Marco
« Reply #14 on: May 21, 2019, 04:16:24 PM »
Thanks for testing.
Please try; thanks.
:-) V19/A2020 all ok now!  :yes:
