Author Topic: Object names for selection sets  (Read 1923 times)
pjm8765
« on: May 20, 2019, 05:27:18 AM »
I could have sworn I have seen a reference that lists all of the major object names that can be provided as a filter rule for a selection set:
typedArray.SetValue(new TypedValue((int)DxfCode.Start, "INSERT"), 0);
So, an INSERT is obviously a block reference ( :thinking:) and CIRCLE and LINE are also obvious.  But what about a dimension and the rest of the objects?  Any pointers, much appreciated.
Keith Brown
Re: Object names for selection sets
« Reply #1 on: May 20, 2019, 09:07:52 AM »
I believe that you just use the DXFName.  That is the name that pops up when you List the object at the command line.
huiz
  • Certified Prof C3D
« Reply #2 on: May 20, 2019, 09:09:06 AM »
You can use the LIST command in AutoCAD to check the object DXF name.
huiz
« Reply #3 on: May 20, 2019, 09:12:15 AM »
Here is a DXF Reference file:
https://images.autodesk.com/adsk/files/autocad_2012_pdf_dxf-reference_enu.pdf
Different objects are described from page 61.
pjm8765
« Reply #4 on: May 20, 2019, 10:50:51 AM »
Thanks very, that reference will come in very handy.
