Author Topic: BFindV2 - sorting by length not alphabetically  (Read 2717 times)
dami
« on: May 18, 2019, 07:30:32 AM »
Hello,
I'm using BFindV2 by Lee Mac (http://www.lee-mac.com/bfind.html) and came across a problem when source text cannot be found because it contained the word which have been already replaced. Easy solution for this can be just sorting all elements of list by lenght - longer element can not be included in shorter one.
I noticed that elements of the list are being sorted alphabetically. Was trying to get into code, but have never using LISP before.
Probably this method is doing the job:
  (defun _SortByFirst ( lst )
    (vl-sort lst (function (lambda ( a b ) (< (car a) (car b)))))
I was trying this:
(vl-sort lst (function (lambda ( a b ) (< (length a) (length b)))))
...but It does not work. I probably misunderstand the code.
Please, can you guys help me?
best,
D
Dlanor
Re: BFindV2 - sorting by length not alphabetically
« Reply #1 on: May 18, 2019, 08:10:33 AM »
Hello,
I was trying this:
best,
D
Perhaps
  1.  (vl-sort lst (function (lambda ( a b ) (< (strlen (car a)) (strlen (car b))))))
dami
« Reply #2 on: May 18, 2019, 05:32:49 PM »
Nope, it doesn't sort properly.
Well, I just sorted my .txt file and left fuction in such silly definition:
    lst
At least I achieved what I wanted :-)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #3 on: May 18, 2019, 06:02:52 PM »
    lst
It's very difficult not to laugh ...
Called Kerry in my other life
I live at UTC + 13.00
roy_043
  • BricsCAD 18
« Reply #4 on: May 19, 2019, 10:17:23 AM »
Probably '<' should be '>' in Dlanor's suggestion.
Dlanor
« Reply #5 on: May 19, 2019, 07:23:01 PM »
  1. (vl-sort lst (function (lambda ( a b ) (< (length a) (length b)))))
I was just following the OP's attempt  :whistling:
