Author Topic: Civil3D - Point Style to Point Group  (Read 5129 times)
MSTG007
« on: May 17, 2019, 11:14:33 AM »
I figured I would ask.
Jeff was nice enough awhile ago to put together this code. It works. But, I was hoping I could get it filter by a point label style rather than what is visible on the screen.
https://www.theswamp.org/index.php?topic=52379.msg573254#msg573254
;;Civil 3d - Tool to place all currently visible Cogo Points in a new PointGroup
(defun c:HideDisplayedPoints
       (/ ENT IDX PG PGQUERY PNSTRING PNTNUMS PNTOBJ SS)
  ;;Function to return a PointGroup or add it if it doesn't exist.
  (defun CreatePG (grpname / C3D C3Ddoc exists grps)
    (if (and (setq C3D (strcat "HKEY_LOCAL_MACHINE\\"
       (if vlax-user-product-key
(vlax-user-product-key)
(vlax-product-key)
   C3D (vl-registry-read C3D "Release")
   C3D (substr
C3D
1
(vl-string-search
   C3D
   (+ (vl-string-search "." C3D) 1)
   C3D (vla-getinterfaceobject
(vlax-get-acad-object)
(strcat "AeccXUiLand.AeccApplication." C3D)
     (setq C3Ddoc (vla-get-activedocument C3D))
     (setq grps (vlax-get C3Ddoc 'pointgroups))
(vlax-for pg grps
  (if (eq (vlax-get pg 'name) grpname)
    (setq exists pg)
(if (not exists)
  (setq exists (vlax-invoke-method grps 'Add grpname))
    exists
  ;;next 2 functions as posted to the Swamp by ElpanovEvgeniy (except edited function names)
  ;; https://www.theswamp.org/index.php?topic=12943.msg157773#msg157773
  (defun ints2rangedstring (lst)
    (if lst
      (if (listp (car lst))
(if (cadr lst)
  (if (equal (1+ (cadar lst)) (cadr lst) 1e-8)
    (ints2rangedstring
      (cons (list (caar lst) (cadr lst)) (cddr lst))
    (strcat (itoa (caar lst))
    (itoa (cadar lst))
    (ints2rangedstring (cdr lst))
  ) ;_  if
  (strcat (itoa (caar lst)) "-" (itoa (cadar lst)))
) ;_  if
(if (cadr lst)
  (if (equal (1+ (car lst)) (cadr lst) 1e-8)
    (ints2rangedstring
      (cons (list (car lst) (cadr lst)) (cddr lst))
    (strcat (itoa (car lst)) "," (ints2rangedstring (cdr lst)))
  ) ;_  if
  (itoa (car lst))
) ;_  if
      ) ;_  if
    ) ;_  if
  ;;not used, but left in in case the need to update an existing string arises
  (defun rangedstring2list (s)
    (if s
      (if (listp s)
(if (and (cadar s) (< (caar s) (cadar s)))
  (cons (caar s)
(rangedstring2list
  (cons (list (1+ (caar s)) (cadar s)) (cdr s))
  (cons (caar s) (rangedstring2list (cdr s)))
(rangedstring2list
  (read
    (strcat
      (apply
(function strcat)
(mapcar
  (function
    (lambda (x)
((< 47 x 58) (chr x))
((= 44 x) ")(")
((= 45 x) " ")
      ) ;_  cond
    ) ;_  lambda
  ) ;_  function
  (vl-string->list s)
) ;_  mapcar
      ) ;_  apply
    ) ;_  strcat
  ) ;_  read
) ;_  test
      ) ;_  if
    ) ;_  if
  ;;main part of this tool
  (if (setq ss (ssget "C"
      (getvar 'extmin)
      (getvar 'extmax)
      '((0 . "AECC_COGO_POINT"))
     (setq idx -1)
      (while (setq ent (ssname ss (setq idx (1+ idx))))
(setq pntobj (vlax-ename->vla-object ent))
(if (not pntnums)
  (setq pntnums (list (vlax-get pntobj 'number)))
  (setq pntnums (cons (vlax-get pntobj 'number) pntnums))
      (setq pg (createPG "NO DISPLAY"))
      (vlax-put pg 'overridepointstyle :vlax-true)
      (vlax-put pg 'overridepointlabelstyle :vlax-true)
      (setq pgquery (vlax-get pg 'querybuilder))
      (setq pnString (ints2rangedstring pntnums))
      (vlax-put pgquery 'includenumbers pnString)
« Last Edit: May 17, 2019, 11:48:43 AM by MSTG007 »
Civil3D 2020
Re: Civil3D - Point Style to Point Group
« Reply #1 on: May 17, 2019, 02:31:22 PM »
(if (not pntnums)
mayhaps this portion can be changed to read pntstyle?
« Reply #2 on: May 18, 2019, 10:30:54 AM »
This will do what you want.
  1. ;;Civil 3d - Tool to place all Cogo Points with a specific style in the No Display PointGroup
  2.
  3. (defun c:HidePointsByStyle
  4.        (/ C3D C3Ddoc ENT IDX PG PGQUERY PNSTRING PNTNUMS PNTOBJ SS)
  5.   ;;Function to return a PointGroup or add it if it doesn't exist.
  6.   (defun getC3D ()
  7.     (vl-load-com)
  8.     (setq C3D (strcat "HKEY_LOCAL_MACHINE\\"
  9.                       (if vlax-user-product-key
  10.                         (vlax-user-product-key)
  11.                         (vlax-product-key)
  12.                       )
  13.               )
  14.           C3D (vl-registry-read C3D "Release")
  15.           C3D (substr
  16.                 C3D
  17.                 1
  18.                 (vl-string-search
  19.                   "."
  20.                   C3D
  21.                   (+ (vl-string-search "." C3D) 1)
  22.                 )
  23.               )
  24.           C3D (vla-getinterfaceobject
  25.                 (vlax-get-acad-object)
  26.                 (strcat "AeccXUiLand.AeccApplication." C3D)
  27.               )
  28.     )
  29.     (setq C3Ddoc (vla-get-activedocument C3D))
  30.   )
  31.
  32.   (defun CreatePG (grpname / exists grps)
  33.     (setq grps (vlax-get C3Ddoc 'pointgroups))
  34.     (vlax-for pg grps
  35.       (if (eq (vlax-get pg 'name) grpname)
  36.         (setq exists pg)
  37.       )
  38.     )
  39.     (if (not exists)
  40.       (setq exists (vlax-invoke-method grps 'Add grpname))
  41.     )
  42.     exists
  43.   )
  44.
  45.   ;;next 2 functions as posted to the Swamp by ElpanovEvgeniy (except edited function names)
  46.   ;; https://www.theswamp.org/index.php?topic=12943.msg157773#msg157773
  47.   (defun ints2rangedstring (lst)
  48.     (if lst
  49.       (if (listp (car lst))
  50.         (if (cadr lst)
  51.           (if (equal (1+ (cadar lst)) (cadr lst) 1e-8)
  52.             (ints2rangedstring
  53.               (cons (list (caar lst) (cadr lst)) (cddr lst))
  54.             )
  55.             (strcat (itoa (caar lst))
  56.                     "-"
  57.                     (itoa (cadar lst))
  58.                     ","
  59.                     (ints2rangedstring (cdr lst))
  60.             )
  61.           ) ;_  if
  62.           (strcat (itoa (caar lst)) "-" (itoa (cadar lst)))
  63.         ) ;_  if
  64.         (if (cadr lst)
  65.           (if (equal (1+ (car lst)) (cadr lst) 1e-8)
  66.             (ints2rangedstring
  67.               (cons (list (car lst) (cadr lst)) (cddr lst))
  68.             )
  69.             (strcat (itoa (car lst)) "," (ints2rangedstring (cdr lst)))
  70.           ) ;_  if
  71.           (itoa (car lst))
  72.         ) ;_  if
  73.       ) ;_  if
  74.       ""
  75.     ) ;_  if
  76.   )
  77.
  78.
  79.   ;;main part of this tool
  80.   (getC3D)
  81.   (setq sname
  82.          (getstring
  83.            "\nEnter name of PointStyle of points to add to the No Display Group: "
  84.          )
  85.   )
  86.   (if (and sname
  87.            (/= "" sname)
  88.       )
  89.     (progn
  90.       (setq points (vlax-get C3Ddoc 'points))
  91.       (vlax-for pntobj points
  92.         (if (setq style (vlax-get pntobj 'style))
  93.         (if (= (vlax-get style 'name) sname)
  94.           (if (not pntnums)
  95.             (setq pntnums (list (vlax-get pntobj 'number)))
  96.             (setq pntnums (cons (vlax-get pntobj 'number) pntnums))
  97.           )
  98.         )
  99.           )
  100.       )
  101.       (setq pg (createPG "NO DISPLAY"))
  102.       (vlax-put pg 'overridepointstyle :vlax-true)
  103.       (vlax-put pg 'overridepointlabelstyle :vlax-true)
  104.       (setq pgquery (vlax-get pg 'querybuilder))
  105.       (setq pnString (ints2rangedstring pntnums))
  106.       (vlax-put pgquery 'includenumbers pnString)
  107.     )
  108.   )
  109.   (princ)
  110. )
  111.
MSTG007
« Reply #3 on: May 18, 2019, 10:34:29 AM »
Ahhhh Jeff. Thank you, I was trying different varibles to get it to work, but no luck. Thank you again.
Civil3D 2020
