Author Topic: Unloaded/Unresolved xRefs  (Read 5238 times)
cmwade77
Re: Unloaded/Unresolved xRefs
« Reply #15 on: May 17, 2019, 05:16:28 PM »
Could be eadily re-written using old school dxf type coding which will should work in AcCoreConsole.
Yup, just have to figure out how to invent another 10 hours in the day....lol
« Reply #16 on: May 17, 2019, 05:37:34 PM »
Fugly but try this quick & dirty stab ...
(defun c:dump-xref-shat ( / cmdecho data flags name names f d e )
    (setq cmdecho (getvar 'cmdecho))
    (setvar 'cmdecho 0)
    (while (setq data (tblnext "block" (null data)))
        (and
            (eq 4 (logand 4 (setq flags (cdr (assoc 70 (setq data (entget (tblobjname "block" (cdr (assoc 2 data))))))))))
            (zerop (logand 32 flags))
            (wcmatch (setq name (cdr (assoc 2 data))) "~*|*")
                (foreach p (entget (cdr (assoc 330 data)))
                    (if (eq 331 (car p))
                            (entmod
                                (subst
                                    (cons
                                        70
                                        (logand
                                            (~ 4)
                                            (cdr
                                                (setq f
                                                    (assoc
                                                        70
                                                        (setq d
                                                            (entget
        (tblobjname
        "layer"
        (cdr
        (assoc 8
        (entget
        (setq e (cdr p))
                                    f
                                    d
                            (entdel e)
                (setq names (cons name names))
    (foreach name names (command ".xref" "_detach" name))
    (setvar 'cmdecho cmdecho)
Cheers.
