this is a post in discussion groups
Re: Can't save layerstate
I found if I don't use the acLsAll mask and use instead the mask below it works.
(setq what (+ acLsAll, acLsColor, acLsFrozen, acLsLineType, acLsLineWeight, acLsLocked, acLsNewViewport, acLsNone, acLsOn, acLsPlot, acLsPlotStyle))
I hacked this acLsAll worth 65535 and the sum of all other masks is 511
with that I just keep adding till I got all states to be on and that was this:
Try this formula (1+ (* acLsAll 2)) or simply 131071. Below is a visual explaination of all this: the name of the mask, the decimal value and the binary value.
acLsNone 0 00000000000000000
acLsOn 1 00000000000000001
acLsFrozen 2 00000000000000010
acLsLocked 4 00000000000000100
acLsPlot 8 00000000000001000
acLsNewViewport 16 00000000000010000
acLsColor 32 00000000000100000
acLsLineType 64 00000000001000000
acLsLineWeight 128 00000000010000000
acLsPlotStyle 256 00000000100000000
acLsAll 65535 01111111111111111
acLsAll + 1 10000000000000000
(+ 1 (* acLsAll 2)) 11111111111111111
For example, having a value of 41 means 1 + 8 + 32 so it represents the sum of acLsOn + acLsPlot + acLsColor.
(setq what (1+ (* acLsAll 2)))
This should work, but doesn't.... won't show the layerstate in the
acad layermanager layerstate dialog box.. but this one does.
(setq what (+ 66047 acLsnone acLson acLsnewviewport acLslineweight acLslocked acLslinetype acLson acLsColor acLsFrozen acLsPlot acLsPlotStyle))
or
(setq what (+ 66559))
used like this: where SaveLayerState is the function call
name is the Layerstate name
what is the Mask
(SaveLayerStateName name what)
This is the error:
(SaveLayerStateName name acLsall)
also
The will save a layerstate but won't report it in the acad layermanager layerstates dialog box.... I hope this helps
I also apologize for the code left in earlier posts... I didn't find this error till
just about 4 days ago, and Bam... now I have to suck it up. I hope
that these posts will make up for the learning curve.
Thanks to the Swamp and the people here who share.
I'm working in 2005-2006 and ldt civil3d
Mike in Alaska
this was a pain to find this acad error
I'm a fan of using tablayout name to store the layerstate
and use a command line instead of the acad Layermanager
;;; Organized and tested some programming by Michael Perry
;;; doggarn@nc.rr.com Anchorage Alaska
;;; Help by
;;; Save the LayerState
;;; By Serge Camire, Cad-Novation, http://www.cadnovation.com, 2005/06/07
;;; Usage : (SaveLayerStateName "the_name" what)
(defun c:sss ( / name what )
(setq name (getvar "ctab"))
(c:ssd)
(setvar "cmdecho" 0)
(princ (strcat "\nLayState Saved = " name " \n"))
(GRAPHSCR)
(defun SaveLayerStateName (
;; Choose Mask from (you can sum them up or use acLsAll) :
;; acLsAll, acLsColor, acLsFrozen, acLsLineType, acLsLineWeight, acLsLocked,
;; acLsNewViewport, acLsNone, acLsOn, acLsPlot, acLsPlotStyle
LayerStateName Mask
/ acadapp acadver docs oLSM oLSMDatabase thisDatabase thisDrawing
(setq acadver (itoa (atoi (getvar "acadver"))))
(setq acadapp (vlax-get-acad-object))
(setq docs (vla-get-Documents acadapp))
(setq thisDrawing (vla-get-ActiveDocument acadapp))
(setq thisDatabase (vla-get-Database thisDrawing))
(setq oLSM (vla-GetInterfaceObject acadapp (strcat "AutoCAD.AcadLayerStateManager." acadver)))
(setq oLSMDatabase (vla-SetDatabase oLSM ThisDatabase))
(vla-SetDataBase oLSM thisDatabase)
(vl-catch-all-apply 'vla-save (list oLSM LayerStateName Mask))
;(vla-Regen thisDrawing acAllViewports)
;;; DeleteLayerStateName
(defun DeleteLayerStateName (
LayerStateName
(vl-catch-all-apply 'vla-delete (list oLSM LayerStateName))
;;; Restore TabLayout Name Layer State*********************************** restore *********************************
(defun c:ssr (/ layr layrs name )
(setvar "cmdecho" 0)(GRAPHSCR)
(setq layr (strcase (getvar "ctab")))
(setq layrs (listSavedLayerstates))
(if layrs (setq layrs (mapcar 'strcase layrs)))
(if (not (member layr layrs))
(princ (strcat "\n No LayState = " name " \n"))
(RestoreLayerStateName name)
;;; listSavedLayerstates
;;; Returns a list of all layer states
;;; by Serge Camiré, www.cadnovation.com
;;; Since layer 0 is always involved in a drawing, thus in any subsequent saved layer state,
;;; we scan this layer.
;;; Receive:
;;; no parameters
;;; Returns
;;; LIST or nil
(defun listSavedLayerstates (
/ return
((not (setq return (entget (cdr (assoc 330 (entget (tblobjname "layer" "0"))))))) (setq return nil))
((not (setq return (cdr (assoc 360 return)))) (setq return nil))
((not (setq return (member (cons 3 "ACAD_LAYERSTATES") (entget return)))) (setq return nil))
(t
(setq return (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= 3 (car x))) (entget (cdadr return)))))
return
