Author Topic: LaState Sav-Restr-Del Clened/Impved Sped & acad errs fnd  (Read 2907 times)
sourdough
« on: June 09, 2005, 04:10:34 PM »
this is a post in discussion groups
 Re: Can't save layerstate
 I found if I don't use the acLsAll mask and use instead the mask below it works.
 (setq what (+ acLsAll, acLsColor, acLsFrozen, acLsLineType, acLsLineWeight, acLsLocked, acLsNewViewport, acLsNone, acLsOn, acLsPlot, acLsPlotStyle))
I hacked this acLsAll worth 65535 and the sum of all other masks is 511
with that I just keep adding till I got all states to be on and that was this:
Try this formula (1+ (* acLsAll 2)) or simply 131071. Below is a visual explaination of all this: the name of the mask, the decimal value and the binary value.
acLsNone         0  00000000000000000
acLsOn           1  00000000000000001
acLsFrozen       2  00000000000000010
acLsLocked       4  00000000000000100
acLsPlot         8  00000000000001000
acLsNewViewport 16  00000000000010000
acLsColor       32  00000000000100000
acLsLineType    64  00000000001000000
acLsLineWeight 128  00000000010000000
acLsPlotStyle  256  00000000100000000
acLsAll      65535  01111111111111111
acLsAll + 1         10000000000000000
(+ 1 (* acLsAll 2)) 11111111111111111
For example, having a value of 41 means 1 + 8 + 32 so it represents the sum of acLsOn + acLsPlot  + acLsColor.
(setq what (1+ (* acLsAll 2)))
This should work, but doesn't.... won't show the layerstate in the
acad layermanager layerstate dialog box.. but this one does.
(setq what (+ 66047 acLsnone acLson acLsnewviewport acLslineweight acLslocked acLslinetype acLson acLsColor acLsFrozen acLsPlot acLsPlotStyle))
or
(setq what (+ 66559))
used like this: where SaveLayerState is the function call
                    name is the Layerstate name
                    what is the Mask
(SaveLayerStateName name what)
This is the error:
(SaveLayerStateName name acLsall)
also
The will save a layerstate but won't report it in the acad layermanager layerstates dialog box.... I hope this helps
I also apologize for the code left in earlier posts... I didn't find this error till
just about 4 days ago, and Bam... now I have to suck it up. I hope
that these posts will make up for the learning curve.
Thanks to the Swamp and the people here who share.
I'm working in 2005-2006 and ldt civil3d
Mike in Alaska
this was a pain to find this acad error
I'm a fan of using tablayout name to store the layerstate
and use a command line instead of the acad Layermanager
;;; Organized and tested some programming by Michael Perry
;;; doggarn@nc.rr.com Anchorage Alaska
;;; Help by
;;; Save the LayerState
;;; By Serge Camire, Cad-Novation, http://www.cadnovation.com, 2005/06/07
;;; Usage : (SaveLayerStateName "the_name" what)
(defun c:sss ( / name what )
       (setq name (getvar "ctab"))
       (c:ssd)
       (setvar "cmdecho" 0)
       (princ (strcat "\nLayState Saved = " name " \n"))
        (GRAPHSCR)
(defun SaveLayerStateName (
       ;; Choose Mask from (you can sum them up or use acLsAll) :
       ;; acLsAll, acLsColor, acLsFrozen, acLsLineType, acLsLineWeight, acLsLocked,
       ;; acLsNewViewport, acLsNone, acLsOn, acLsPlot, acLsPlotStyle
       LayerStateName Mask
     / acadapp acadver docs oLSM oLSMDatabase thisDatabase thisDrawing
       (setq acadver (itoa (atoi (getvar "acadver"))))
       (setq acadapp (vlax-get-acad-object))
       (setq docs (vla-get-Documents acadapp))
       (setq thisDrawing  (vla-get-ActiveDocument acadapp))
       (setq thisDatabase (vla-get-Database thisDrawing))
       (setq oLSM (vla-GetInterfaceObject acadapp (strcat "AutoCAD.AcadLayerStateManager." acadver)))
       (setq oLSMDatabase (vla-SetDatabase oLSM ThisDatabase))
       (vla-SetDataBase oLSM thisDatabase)
       (vl-catch-all-apply 'vla-save (list oLSM LayerStateName Mask))
       ;(vla-Regen thisDrawing acAllViewports)
 ;;; DeleteLayerStateName
   (defun DeleteLayerStateName (
      LayerStateName
      (vl-catch-all-apply 'vla-delete (list oLSM LayerStateName))
;;; Restore TabLayout Name Layer State*********************************** restore *********************************
 (defun c:ssr (/ layr layrs  name )
  (setvar "cmdecho" 0)(GRAPHSCR)
      (setq layr (strcase (getvar "ctab")))
    (setq layrs (listSavedLayerstates))
    (if layrs (setq layrs (mapcar 'strcase layrs)))
    (if (not (member layr layrs))
    (princ (strcat "\n No LayState = " name " \n"))
    (RestoreLayerStateName name)
;;; listSavedLayerstates
;;; Returns a list of all layer states
;;; by Serge Camiré, www.cadnovation.com
;;; Since layer 0 is always involved in a drawing, thus in any subsequent saved layer state,
;;; we scan this layer.
;;; Receive:
;;;   no parameters
;;; Returns
;;;    LIST or nil
(defun listSavedLayerstates (
 / return
      ((not (setq return (entget (cdr (assoc 330 (entget (tblobjname "layer" "0"))))))) (setq return nil))
      ((not (setq return (cdr (assoc 360 return)))) (setq return nil))
      ((not (setq return (member (cons 3 "ACAD_LAYERSTATES") (entget return)))) (setq return nil))
      (t
         (setq return (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= 3 (car x))) (entget (cdadr return)))))
   return
LDC 2009/C3D 2010/C3D 2011/C3D 2016
Win 10 64bit
