Author Topic: Can't trim 2 splines  (Read 2127 times)
Karol
  • Mosquito
« on: May 08, 2019, 08:31:17 PM »
On R13, these 2 splines (one is a straight line) can't be trimmed with one another
ribarm
  • Marko Ribar, architect
Re: Can't trim 2 splines
« Reply #1 on: May 09, 2019, 01:19:12 AM »
Planarize spline and line and then check for intersection using intersectwith method... If it returns point coordinates, it means there is intersection... Then, I suppose trimming will be possible - not tested though...
Intersectwith method :
(vlax-invoke (vlax-ename->vla-object (car (entsel "\nPick LINE..."))) 'intersectwith (vlax-ename->vla-object (car (entsel "\nPick SPLINE..."))) acextendnone)
The main problem here is how to planarize 3D entity - SPLINE with 1D entity - LINE... Well You could try using OSNAPS : command MOVE, pick point on SPLINE with "_nea" OSNAP and as destination point pick point on LINE with "_nea" OSNAP... If SPLINE is 2D they will be planarized, but if it's 3D, I suppose you could be able to trim one side from intersection point and the other side should remain IMHO...
HTH., M.R.
M.R. on Youtube
« Reply #2 on: May 09, 2019, 10:13:36 AM »
try to FLATTEN them
