Author Topic: is there somebody able to TRANSLATE the comments of 3d_lib ?  (Read 2375 times)
domenicomaria
is there somebody able to TRANSLATE the COMMENTS of 3d_lib ?
Because I am not able, for instance,
to understand
what
this (and all the others) function does :
; Рассчет центрального угла дуги
;Параметры
; Pn, Pk, Pc - начальная, конечная и центральная точки дуги
; WNorm - вектор нормали к плоскости дуги
; Возвращает центральный угол дуги в радианах
(defun 3d_arcnkc_ang (Pn Pk Pc WNorm / Ang Pc_)
 (setq WNorm (3d_ort WNorm)
       Pc_ (trans Pc 0 WNorm)
       Ang (- (angle Pc_ (trans Pk 0 WNorm)) (angle Pc_ (trans Pn 0 WNorm)))
 (if (or (< (abs Ang) $Dopusk) (equal (abs Ang) 2Pi $Dopusk)) (setq Ang 0.0))
 (if (minusp Ang) (+ Ang 2Pi) Ang)
« Last Edit: May 01, 2019, 02:29:36 PM by domenicomaria »
ChrisCarlson
Re: is there somebody able to TRANSLATE the comments of 3d_lib ?
« Reply #1 on: May 01, 2019, 02:51:49 PM »
Try this
domenicomaria
« Reply #2 on: May 01, 2019, 03:34:16 PM »
... But it is the same !
I need to understand
what the function does
and what kind of arguments
I have to pass to it
But it is not possible to understand this !
I can only suppose something !
; Точка пересечения прямой и плоскости
;Параметры:
;P1, P2 - точки на прямой
;Ppl - точка в плоскости
;WNorm - вектор нормали к плоскости
;Возвращает: точку пересечения прямой и плоскости или nil
(defun 3d_inters_lnpl (P1 P2 Ppl WNorm / A B C D L M N Tpr V)
 (mapcar 'set '(L M N) (mapcar '- P2 P1)) ; вектор прямой
 (mapcar 'set '(A B C) WNorm)
 (if (not (equal (setq V (+ (* A L) (* B M) (* C N))) 0.0 $Dopusk))
   (setq D (- (+ (* A (car Ppl)) (* B (cadr Ppl)) (* C (caddr Ppl))))
    Tpr (- (/ (+ (* A (car P1)) (* B (cadr P1)) (* C (caddr P1)) D) V))
   (list (+ (car P1) (* Tpr L)) (+ (cadr P1) (* Tpr M)) (+ (caddr P1) (* Tpr N)))
VovKa
  • Ukraine
« Reply #3 on: May 01, 2019, 03:52:59 PM »
open this file in notepad++
menu Encoding\Character sets\Cyrillic\Windows-1251
copy text to clipboard
go to translate.google.com
paste
translate from Russian to your language
domenicomaria
« Reply #4 on: May 01, 2019, 04:15:17 PM »
Yes !
It works.
thank you.
« Last Edit: May 01, 2019, 04:25:01 PM by domenicomaria »
domenicomaria
« Reply #5 on: May 02, 2019, 04:06:09 PM »
only 1 file
completely translated
in English
with google translator !
