Author Topic: DOUBLE OFFSET LISP  (Read 4888 times)
raniel1827
DOUBLE OFFSET LISP
« on: May 01, 2019, 01:00:11 AM »
I found this double offset lisp by Lee Mac, very useful. Although any way to modify it in such a way that it would offset asking the total distance of two lines instead of regular offset. example, I need to offset lines to draw pipe, dia of pipe say 273. Command "double offset" distance 273.
;;--------------------=={ Double Offset }==-------------------;;
;;  Offsets each object in a selection to both sides by a     ;;
;;  specified distance. With additional controls for erasure  ;;
;;  of source object and offset layer.                        ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Version: 1-1 20100912                                     ;;
(defun c:DOff nil (c:DoubleOffset))
(defun c:DoubleOffset ( / *error* _StartUndo _EndUndo DoubleOffset doc exitflag layer mpoint obj object of point sel symbol value )
  (defun *error* ( msg )
    (and doc (_EndUndo doc))
    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **")))
  (defun _StartUndo ( doc ) (vla-StartUndoMark doc))
  (defun _EndUndo   ( doc ) (if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-EndUndomark doc)))
  (defun DoubleOffset ( object offset layer )
    (mapcar
      (function
        (lambda ( o )
            (and
              (not
                (vl-catch-all-error-p
                  (setq o
                    (vl-catch-all-apply
                      (function vlax-invoke) (list object 'Offset o)
              layer
            (mapcar
              (function
                (lambda ( o )
                  (vla-put-layer o (getvar 'CLAYER))
              o
      (list offset (- offset))
  (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (mapcar
    '(lambda ( symbol value ) (or (boundp symbol) (set symbol value)))
    '(*dOff:Erase *dOff:Layer) '("No" "Source")
      (while
          (princ
            (strcat
              "\nCurrent Settings: Erase source="
              *dOff:Erase
              "  Layer="
              *dOff:Layer
              "  OFFSETGAPTYPE="
              (itoa (getvar 'OFFSETGAPTYPE))
          (initget 6 "Through Erase Layer")
          (setq of
            (getdist
              (strcat "\nSpecify Offset Distance [Through/Erase/Layer] <"
                (if (minusp (getvar 'OFFSETDIST)) "Through"  (rtos (getvar 'OFFSETDIST))) "> : "
              (null of) (not (setq of (getvar 'OFFSETDIST)))
              (eq "Through" of) (setq of (setvar 'OFFSETDIST -1)) nil
              (eq "Erase" of) (initget "Yes No")
              (setq *dOff:Erase
                    (getkword
                      (strcat "\nErase source object after offsetting? [Yes/No] <" *doff:Erase "> : ")
                  ( *dOff:Erase )
              (eq "Layer" of) (initget "Current Source")
              (setq *dOff:Layer
                    (getkword
                      (strcat "\nEnter layer option for offset objects [Current/Source] <" *dOff:Layer "> : ")
                  ( *dOff:Layer )
            ( of (setvar 'OFFSETDIST of) nil )
      of
    (while
        (or ExitFlag
          (progn (initget "Exit")
            (setq sel (entsel "\nSelect object to offset or [Exit] <Exit> : "))
            (or ExitFlag (null sel) (eq sel "Exit")) nil
          ( (vl-consp sel)
            (_EndUndo doc) (_StartUndo doc)
            (if (and (wcmatch (cdr (assoc 0 (entget (car sel)))) "ARC,CIRCLE,ELLIPSE,SPLINE,LWPOLYLINE,XLINE,LINE")
                     (setq obj (vlax-ename->vla-object (car sel))))
              (if (minusp of)
                  (progn (initget "Exit Multiple")
                    (and
                      (setq point (getpoint "\nSpecify through point or [Exit/Multiple] <Exit> : "))
                      (not (eq "Exit" point))
                  (if (eq "Multiple" point)
                    (while
                        (setq mpoint (getpoint "\nSpecify through point or [Exit] <next object> : "))
                            (eq "Exit" mpoint)
                            (if (eq "Yes" *dOff:Erase) (vla-delete obj))
                            (not (setq ExitFlag t))
                            (null mpoint)
                            nil
                            (listp mpoint)
                            (DoubleOffset obj
                              (distance (trans mpoint 1 0)
                                (vlax-curve-getClosestPointto (car sel) (trans mpoint 1 0) t)
                              (eq "Current" *dOff:Layer)
                           t
                      (DoubleOffset obj
                        (distance (trans point 1 0)
                          (vlax-curve-getClosestPointto (car sel) (trans point 1 0) t)
                     t
                  (setq ExitFlag t)
                  (DoubleOffset obj of (eq "Current" *dOff:Layer))
              (princ "\n** Cannot Offset that Object **")
           t
  (_EndUndo doc) (princ)
(vl-load-com) (princ)
(princ "\n:: DoubleOffset.lsp | Version 1.1 | © Lee Mac 2011 www.lee-mac.com ::")
(princ "\n:: Type \"DoubleOffset\" or \"DOff\" to invoke ::")
;;                         End of File                        ;;
BIGAL
  • 40 + years of using Autocad
Re: DOUBLE OFFSET LISP
« Reply #1 on: May 01, 2019, 02:17:38 AM »
Whilst Lee writes great code I took a different approach to draw pipes of 2 lines, I load a lisp which has the pipe size offset preset, so type p300 will be an ID 0f 300 OD of 380 this is for concrete pipes.
« Reply #2 on: May 01, 2019, 02:02:21 PM »
You could either type 273/2 at the prompt, or change line 123 of the program from:
  1. ( of (setvar 'OFFSETDIST of) nil )
To:
  1. ( of (setq of (/ of 2.0)) (setvar 'OFFSETDIST of) nil )
